Topic: [solved] Ubuntu C++ <--> Mega2560 Serial Communication (Read 5306 times) previous topic - next topic
Nathax
Jul 23, 2013, 11:46 am Last Edit: Jul 25, 2013, 12:37 am by Nathax Reason: 1
Hello,
I would like to communicate with my Arduino Mega2560 under Ubuntu with C++.
I couldn't find a working code in the web.
Does anybody know, how to solve my problem?
Nathan
PaulS
Quote
Unbelievable.
Quote
Google again. Perhaps with a less narrow search. C++ on Ubuntu, windoze, etc. is the same.
tigerbomb8
Quote
Unbelievable.
Quote
What's windoze? I have never heard of it.
Nathax
The only code I found is up here: http://webtutsdepot.com/2010/05/01/arduino-visual-c-plus-plus-tutorial/
Maybe now you could understand why I would like a Linux tutorial, because clr isn't possible in codeblocks, afaik.
Any advises?
enhzflep
It really is dead easy you know!
It's as simple as this - the serial ports (both in windows and *nix) may be read using the very same interface used to read files.
So, all you need to do is call fopen with the name of the serial port device as the filename.
You then read/write from/to the 'file'. It's a 27 line program to provide a dodgy read-only 'Serial Monitor' like the one in the arduino ide.
Here's the first 11 lines of something I threw together. You'll be fine from here. If you can read from a disk file, serial ports are just as easy to get started with.
If not, research how to read from a file.
Just make sure you change the serialPortFilename to reflect the port you're actually connected to (you can see it in the bottom right corner of the arduino ide, in the status-bar)
Code: [Select]
#include <stdio.h>
#include <string.h>
char serialPortFilename[] = "/dev/ttyACM0";
int main()
    char readBuffer[1024];
    int numBytesRead;
    FILE *serPort = fopen(serialPortFilename, "rwb");
Nathax
#5
Jul 25, 2013, 12:21 am Last Edit: Jul 25, 2013, 12:37 am by Nathax Reason: 1
Solution for reading from serial port:
Code: [Select]
#include <stdio.h>
#include <string.h>
int main()
    int numBytesRead;
    FILE *serPort = fopen(serialPortFilename, "r");
if (serPort == NULL)
printf("ERROR");
return 0;
printf(serialPortFilename);
printf(":\n");
while(1)
memset(readBuffer, 0, 1024);
fread(readBuffer, sizeof(char),1024,serPort);
if(sizeof(readBuffer) != 0)
printf(readBuffer);
return 0;
Writing to serial port:
Code: [Select]
#include <stdio.h>
#include <string.h>
char serialPortFilename[] = "COM5";
int main()
FILE *serPort = fopen(serialPortFilename, "w");
printf("ERROR");
return 0;
char writeBuffer[] = {'1'};
fwrite(writeBuffer, sizeof(char), sizeof(writeBuffer), serPort);
fclose(serPort);
return 0;
Thanks for your help. :)
enhzflep
Ripper!
Learning is a lot of fun. Helping someone else to learn feels even better!
