Topic: [solved] debugging atmega328 w/ pl2303 (ebay usb $1.50 adapter) (Read 2732 times) previous topic - next topic
grendle
Jul 23, 2013, 06:26 pm Last Edit: Jul 23, 2013, 08:06 pm by grendle Reason: 1
morning all. apologies if this is in the wrong section, couldnt decide where to put it. this is not a 'how do i upload a sketch with this cheap adapter' question. i simply want to debug a breadboard atmega328p (3.3v 8Mhz). few months ago i was playing with an attiny85 and this adapter, and i got it talking fine, i cant get squat out with my current setup. any code (using examples) simple Serial.print("hello"); etc etc. im using the 3.3v output on the adapter, ground on the adapter, and rx line via 1k resistor to the tx line on the atmega. any advice appreciated. thank you.
http://www.ebay.com/itm/1pc-PL2303-USB-To-RS232-TTL-Converter-Adapter-Module-F-Arduino-CAR-Detection-GPS-/271234585265?pt=LH_DefaultDomain_0&hash=item3f26d752b1
johnwasser
It appears to have RX and TX lights ("Two data transmission indicator can monitor data transfer status in real time").  Do they blink in the expected patterns?
grendle
no, ive used 2 different atmegas to make sure one wasnt damaged. the power light is on - on the adapter. also, i have 2 of these adapters im trying, just in case one is damaged. i usually order stuff in twos. to me this should be a simple thing lol, very confused. the breadboard setup is minimal, atmega, xtal, xtal caps, thats it. (the entire circuit is a receiver for weatherstation. but since it didnt work from get go, im working with stripped breadboard. also, on an uno without sdcard this works fine. im building it on a breadboard to stay with the 3.3v because i want to add the sdcard, but i cant even get it to spit out "hello world" to the pc lol.
// receive w/ sd card support. add clock?
#include <SD.h>
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
const int chipSelect = 8; //sd card
const uint64_t pipe = 0xE8E8F0F0E1LL; //pipe
typedef struct{
  float T; //temperature
  float RH;
  float HI;
  float DP;
  float pressure;
payload;
payload ard1;
RF24 radio(9,10);
  ADCSRA &= ~(1<<ADEN); //Disable ADC
  ACSR = (1<<ACD); //Disable the analog comparator
  DIDR0 = 0x3F; //Disable digital input buffers on all ADC0-ADC5 pins
  DIDR1 = (1<<AIN1D)|(1<<AIN0D); //Disable digital input buffer on AIN1/0
  //  power_adc_disable();
  Serial.begin(57600);
  pinMode(7, OUTPUT); //write error
  pinMode(8, OUTPUT); //cs sd card
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    digitalWrite(7,HIGH); //error
    // don't do anything more:
    return;
  Serial.println("card initialized.");
  File dataFile = SD.open("datalog.csv", FILE_WRITE);
  if (dataFile) { //file header
    dataFile.println("Decimal Minutes (GPS): N32 31.581409999999998 W86 23.3472 Date: ");
    dataFile.print("Temperature");
    dataFile.print(",");
    dataFile.print("Pressure");
    dataFile.print("Humidity");
    dataFile.print("Dew Point");
    dataFile.println("Heat Index");
    dataFile.close();
  radio.begin();
  radio.openReadingPipe(1,pipe);
  radio.startListening();
  if ( radio.available() )
    // Dump the payloads until we've gotten everything
    boolean done = false;
    while (!done)
      // Fetch the payload, and see if this was the last one.
      done = radio.read( &ard1, sizeof(ard1) );
      Serial.print(ard1.T);
      Serial.println(" oF");
      Serial.print(ard1.pressure);
      Serial.println(" in/Hg");
      Serial.print(ard1.RH);
      Serial.println(" % Hum");
      Serial.print(ard1.DP);
      Serial.println(" Dew Point");
      Serial.print(ard1.HI);
      Serial.println(" Feels like");
  if (dataFile) {
    dataFile.print(ard1.T);
    dataFile.print(ard1.pressure);
    dataFile.print(ard1.RH);
    dataFile.print(ard1.DP);
    dataFile.println(ard1.HI);
    dataFile.close();
grendle
i found this from crossroads
quote:
So which is it? USB to TTL (0 to 5V signals), or USB to RS232 (+/- 10V signals)?
Sounds like it has a 3.3V output as well.
http://prolificusa.com/files/ds_pl2303HXD_v1.4.3.pdf
See page 18 for a typical usage of the chip with a RS232 transceiver chip.
If TTL, you can connect the Rx & Tx to the appropriate pins on your Arduino; Tx and Rx.
If its RS232, then you need an RS232 adapter to bring the levels from +/-10V down to 0-5V levels.
Does your PC have PL2303 USB drivers installed?
end quote:
this may be my problem hmm? im using 3.3v, let me set it up at 5 v and see what happens.
grendle
yup that was it, works fine with 5volts. ok so this means the sd card moves to the actual weatherstation unit, and not the receiver. oh well, live and learn. thank you John! (and crossroads lol.)
