Topic: Have i done something bad? (Read 683 times) previous topic - next topic
MrBear
Jul 24, 2013, 04:42 pm Last Edit: Jul 24, 2013, 04:46 pm by MrBear Reason: 1
Hi
I am using the PID library to create a servomotor (DC motor with a POT) but had some problems making my motor turn in both directions. What i did was to change the Input and Setpoint pin hereby making the setpointpin the inputpin. ...... it seems to work but..?
Code: [Select]
#include <PID_v1.h>
double error;
//Define Variables we'll be connecting to
double Setpoint, Input, Output;
//Specify the links and initial tuning parameters
PID myPID(&Input, &Output, &Setpoint,20,0,0, DIRECT);
TCCR2B = 0x01;   // Timer 2: PWM 3 & 11 @ 32 kHz
 //initialize the variables we're linked to
 Input = analogRead(A3);
 Setpoint = analogRead(A1);
 //turn the PID on
 myPID.SetMode(AUTOMATIC);
 double HJULraw = analogRead(A1); //reading the 2 pots to calculate an error
 double RATraw = analogRead(A3);
 error = (RATraw-HJULraw);
 if(error >= 2) {
   TurnR();
 }   else if (error <= -2) {
   TurnL();
   digitalWrite(11, LOW);
    digitalWrite(3, LOW);
void TurnR() {
 Setpoint = analogRead(A3);
 Input = analogRead(A1);
 myPID.Compute();
 Output = map(Output, 0, 255, 0, 150);
 analogWrite(3, 0);
 analogWrite(11,Output);
  Cprint();
void TurnL() {
 Setpoint = analogRead(A1); // THIS IS WHERE THE TWO PINS ARE CHANGED COMPARED TO Void TurnR
 Input = (analogRead(A3));
 myPID.Compute();
 analogWrite(11, 0);
 analogWrite(3, Output);
 Cprint();
void Cprint() {
Serial.write("error: ");
Serial.print(error);
 Serial.write("  potRAT: ");
Serial.print(analogRead(A3));
 Serial.write("  potHJUL: ");
Serial.print(analogRead(A1));
 Serial.write("  Output: ");
Serial.println(Output);
delay(100);
I dont know if this is the way to do it?
Thanks for your help.
pajaraca
I'm not a expert but I think your code is out void loop ().
holmes4
Auto format your code and then look at it again! ( and repost it) the layouts so poor I can't make head or tail of it.
Mark
