Topic: byte - BUG (Read 5180 times) previous topic - next topic
...to reproduce the bug (in V1.0.5) do the following:
1. Start a new sketch
2. type: #include "test.h"
3. add a tab and name it "test.h"
4. type in "test.h": byte x;
5. save and compile
then the following error will appear: "test.h:1: error: 'byte' does not name a type"!
nickgammon
The generated code out of the pre-processing is:
Code: [Select]
#line 1 "sketch_jul24c.ino"
#include "test.h"
#include "Arduino.h"
void setup ();
void loop ();
#line 3
void setup ()
  }  // end of setup
void loop () { }
The work-around is to put:
Code: [Select]
... at the start of test.h.
I'm not sure if this is a bug or not. Another work-around is to make the main sketch read:
Code: [Select]
#include "test.h"
void setup () { }
void loop () { }
Logically this makes sense, as the byte type is declared in Arduino.h (or something it includes). Thus normally when writing in C you would need to include it.
The pre-processor could conceivable put the automated include of "Arduino.h" further up the sketch. There is possibly/probably a reason why they don't.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
nickgammon
I've raised a bug report:
https://github.com/arduino/Arduino/issues/1518
However I should point out that if you wrote a separate .cpp file then the include for "Arduino.h" would be needed. For example if test.cpp includes test.h then there is not automatic addition of include directives to stand-alone compilation units (such as test.cpp or test.h).
pjrc
If anything, this really shows how Arduino's support for .cpp and .h files as tabs in the editor isn't well known or documented.
