Topic: L293D overheated but not burned !! what's the solution ? (Read 17698 times) previous topic - next topic
firashelou
Aiming for the unreachable !
runaway_pancake
#47
Jul 28, 2013, 08:05 pm Last Edit: Jul 28, 2013, 08:09 pm by Runaway Pancake Reason: 1
so about the piece of metal for heat sink, it should be connected with a wire to the pins ?
No, that will not work.
Ideally, those pins (Gnd - 4, 5, 12, 13) should be soldered to a "ground plane", with the underside of the IC laying right on the copper of the "ground plane".  That's how the heat gets drawn out - mechanical, physical contact.
Barring that, any heatsinking will have, at best, only marginal effect.
I would not anticipate any marked result from clamping a piece of metal atop the IC.
The L293 is a #%@& IC that people expect too much from.
> > > Why is this being discussed in "Microcontrollers"?
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
firashelou
can you please show me an example on how to do it by posting a picture ?
i wasn't sure were to ask this question so i chose microcontrollers isn't it ?
runaway_pancake
I have attached ST's datasheet (PDF).
If you look at page 4 of 7 ("4/7") they depict [see "Figure 2"] the sort of board surface required.
I'm not "The Boss", but a L293D is a "four channel driver".
firashelou
ok i saw the picture but i didn't get much what's going on there !! :(
runaway_pancake
I'm sorry but I don't have a CAD package to render you an orthogonal view of the situation and it is beyond my artistic ability to draw it for you.
But, here's a link to Unitrode's datasheet, where they present (see Figure 10) the ideal ground plane vs. the IC outline.
http://www.zagrosrobotics.com/files/L293.pdf
A prototyper of any accomplishment could splay, or "un-bend", all of the pins [except the Gnd pins] out straight from the IC body and solder the Gnd leads to a piece of copper-clad board and then "dead-bug" (etc) all of the other connections from there.
alnath
yes, I was wondering too ...
should be in general electronics, I guess
firashelou
aha ok i saw the figure 11, so the piece of metal should be mounter of a support on the top of the IC and touching the IC ?
if yes, then if i got a pice of metal and put it right there will that be good to get rid of heat or i must solder the GND to a bigger range ?
i am not working on a PCB but on a vero board
firashelou
ok i am sorry about that :S
jack wp
I will put in my last 2 cents worth.
There is no one answer as to how to take away all the heat. There are many things that could be done to reduce the heat, such as: use a better IC, solder it onto a copper clad board, reduce the duty cycle, blow air across it, glue a heat sink on top of the IC, and the list goes on and on. I think we have about exhausted discussions on this little IC.
Jack
firashelou
Jack
yes so what I need to know. about is how to glue the heat sink above the ic?  if we put glue then it will act like a wall between the ic and the metal piece!  so how to do it?
jack wp
Here is one heatsink http://www.circuitspecialists.com/33hs016.html
And a google for "heatsink glue adhesive" finds several glues.
Good Luck, Jack
firashelou
Good Luck, Jack
aha thank you, so I just have to glue it at the top of the chip which in the socket?
jack wp
You stated in your first post:
Code: [Select]
soldered pins : 1, 2, 3, 4,6,7,8
soldered just to the "PCB" : 9, 16
Now you have moved it to a socket?
It will really help to dissipate the heat if you solder it to the PCB, rather than using a socket.
BTW, why are you asking me which IC to put the heatsink on? You know the one that is overheated.
