Topic: Strange logic error with a while loop (Read 3248 times) previous topic - next topic
Jymmy097
I have another strange error (again!)!!
I have an array of longs and I have to find two numbers: 1170000000 or 1180000000.
When I found one of these two numbers (the first or the second, it's the same) I have to break the loop.
I wrote
while (instr[EIP] != 1170000000 || instr[EIP] != 118000000)
  EIP++;
But it continues after it has found the numbers. I put a serial.print instruction just after the while declaration to print all the numbers it find and I found 1170000000! It is a strange comportament!
I'm very confused...
Thanks for your help!
Jymmy097
KeithRB
Put an L after the constant to signify it is long:  117000000L
cypherrage
#2
Jul 26, 2013, 06:21 pm Last Edit: Jul 26, 2013, 06:27 pm by cypherrage Reason: 1
Your logic is wrong, change || to &&.
Essentially you have an infinite loop because the variable cannot simultaneously be both of those numbers. Your current logic says, "if either of those conditions is fulfilled, the loop will continue", whereas you think it says, "if either of those conditions is NOT fulfilled, the loop will NOT continue." Both conditions would have to be fulfilled to break the loop. Change || to && and your problem is solved. New logic says, "Both of these conditions must be fulfilled or else the loop will break."
econjack
The way the code's written:
 EIP++;
If the current value of the array index into instr[] isn't one of those two values to begin with, EIP can't get incremented. Would this work for you?
while (true) {
  if (nstr[EIP] == 1170000000L || instr[EIP] == 118000000L) {
     break;
  EIP++;
KeithRB
I don't think so.
if instr[EIP] == one of the numbers the while will be false and the loop will break.
In other words, as long as instr[EIP] does not equal one of the numbers I am looking for, keep looping.
econjack
The poster says:
Sounds to me that's exactly what he's trying to do. What am I missing?
Jymmy097
The third solution has worked:
While (true)
if (instr[EIP] == 1170000000 || instr[EIP] == 1180000000)
Break;
EIP++;
cyperrage: you're wrong: if I put && instead of || both of the condition have to be fulfilled, only one have to be fulfilled. Anyway: the same variable can't have two different values at the same time.
Thanks a lot!
Jymmy097
KeithRB
cyberrage is right. You need && because for the || to be false and break the loop, *both* have to be false. If only one is true, the || is true.
Delta_G
You want both to be fulfilled in order to keep incrementing.  If either one is fulfilled youwant to stop incrementing.
So if you find 11700000 then the while loop says while (false or true) since 1170000 doesn't equal 1180000 so the while loop keeps incrementing.  You say you want it to stop incrementing if you get either one of those numbers.  So you should use && in the original code and it will work.  That way it says only keep incrementing if the number is not 1170000 or 1180000.  If it is either one of those numbers then the while condition comes back false and it stops incrementing.
You're thing if it equals this OR that, but what you've written is if it is NOT equal to this or NOT equal to that.  That's always true, a number can't equal two things at once.
|| | ||| | || | ||  ~Woodstock
cypherrage
#9
Jul 26, 2013, 07:04 pm Last Edit: Jul 26, 2013, 07:06 pm by cypherrage Reason: 1
While (true)
Break;
EIP++;
Thanks a lot!
Jymmy097
Simply put: No.
Loops work based on the following properties:
1) Whenever the logic inside the parentheses is TRUE, the loop continues.
2) Whenever the logic inside the parentheses is FALSE, the loop breaks.
Let me lay out some Logical operator tables for you. (&& = logical AND, || = logical OR)
  A    |     B     |  AND  |   OR
FALSE | FALSE | FALSE | FALSE
FALSE | TRUE  | FALSE | TRUE
TRUE  | FALSE | FALSE | TRUE
TRUE  | TRUE  | TRUE   | TRUE
Right now, you are using OR, therefore, the loop will ONLY break when the FALSE condition comes up, which only happens when both conditions come up false, which is impossible granted your logic. If you use the AND operator, it is obvious to see that when either condition breaks, the loop will break as well.
Also, as stated above, if you change the != to ==, then your logic will work fine, you just have to change either one, != to ==, or || to &&, the logic will be the same regardless, but you must do either one if you want it to be correct.
econjack
Attached is a simple program that demos what I think jymmy097 is trying to do when he says:
unsigned long instr[] = { 0L, 1L, 2L, 3L, 1170000000L, 0L};
  int EIP = 0;
  while (true) {
     if (instr[EIP] == 1170000000L || instr[EIP] == 118000000L) {
       Serial.print("Match: EIP = ");
       Serial.println(EIP);
        break;
     Serial.print("No match: EIP = ");
     EIP++;
Delta_G
That's sort of the long way round but yes if you want to use == then you can use OR.  If you want to use != like in the OP then you'd use AND.  And you get simpler code that way.
|| | ||| | || | ||  ~Woodstock
Henry_Best
No. Cyperrage is correct.
Lets say your numbers are 117 and 118 for simplicity. With ||...
Input 116. The first condition is true (not 117) and the second condition is true (not 118).
true || true  = true
Input 117. The first condition is false (= 117) and the second condition is true (not 118).
false || true  = true
Input 118. The first condition is true (not 117) and the second condition is false (=118).
true  || false = true
With ANY input the while loop will continue and not exit. For the loop to exit, both inputs would have to be false (equal to both 117 and 118), and as you say, the same variable can't have two different values at the same time.
Now with &&...
true && true  = true
Input 117. The first condition is false (=117) and the second condition is true (not 118).
false && true  = false
true  && false = false
If either input gives a false (equals either 117 or 118) then the while loop will exit.
nickgammon
While (true)
Break;
EIP++;
You changed != to == which reverses the logic (see first post).
Something can't be green AND blue, that's true, but it can be not green AND not blue (eg. it could be red).
However it is always not green OR not blue (if it is green it is not blue, and if it is blue it is not green).
AWOL
