Topic: How to access a WebServer with login by a WebClient (Read 6203 times) previous topic - next topic
AJoao
I want to access a WebServer (Camera IP) with login by a Arduino-WebClient, but I dont know how do it.
I have tried this code on Arduino-WebServer:
if (client.connect(server, 81)) {
    Serial.println("connected");
    // Make a HTTP request:
    //client.println("GET /search?q=arduino HTTP/1.1");
    client.println("GET /myusername:mypassword HTTP/1.1");
    //client.println("Host: www.google.com");
    client.println("Host: IPCamera_Web");
    client.println("Connection: close");
    client.println();
  else {
    // kf you didn't get a connection to the server:
    Serial.println("connection failed");
My WebCamIP response this:
HTTP/1.1 401 Unauthorized
Server: IPCamera-Web
Date: Fri Jul 26 23:50:13 2013
WWW-Authenticate: Basic realm="IPCamera_Web"
Pragma: no-cache
Cache-Control: no-cache
Content-Type: text/html
<html><head><title>Document Error: Unauthorized</title></head>
      <body><h2>Access Error: Unauthorized</h2>
      <p>Access to this document requires a User ID</p></body></html>
How I can get authorization of my WebCamIP, with Arduino, please!
Thank you in advance!
Best regards,
AJoao
johnwasser
From http://en.wikipedia.org/wiki/Basic_access_authentication
When the user agent wants to send the server authentication credentials it may use the Authorization header.
The Authorization header is constructed as follows:
Username and password are combined into a string "username:password"
The resulting string literal is then encoded using Base64
The authorization method and a space i.e. "Basic " is then put before the encoded string.
For example, if the user agent uses 'Aladdin' as the username and 'open sesame' as the password then the header is formed as follows:
Authorization: Basic QWxhZGRpbjpvcGVuIHNlc2FtZQ==
You can learn about Base64 here: http://en.wikipedia.org/wiki/Base64
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
AJoao
Hi johnwasser,
I have tried to program my Arduino-WebClient again, after your post, but I cant access to my WebCam yet.
I have see these links:
Link to converter online: http://www.motobit.com/util/base64-decoder-encoder.asp
http://en.wikipedia.org/wiki/Basic_access_authentication#Client_side
http://s3.amazonaws.com/doc/s3-developer-guide/RESTAuthentication.html
http://www.httpwatch.com/httpgallery/authentication
Part of my Arduino-WebClient code is:
    //client.println("GET /username:pass HTTP/1.1");  // ???
    client.println("GET /username/pass HTTP/1.1");     // ???
    client.println("Host: 192.168.1.244");
    //client.println("Host: IPCamera_Web");
    client.println("Authorization: Basic dXNlcm5hbWU6cGFzcw==");
    client.println();
  else {
The WebCam response:
HTTP/1.1 403 Forbidden
Date: Sat Jul 27 12:53:53 2013
Pragma: no-cache
<html><head><title>Document Error: Forbidden</title></head>
      <body><h2>Access Error: Forbidden</h2>
      <p>Access Denied
Prohibited User</p></body></html>
I dont know here is my bug!!!
Somebody can help me, please!
Best regards,
Ajoao
AJoao
johnwasser
What exact URL do you use to connect to your webcam with a browser?  Does it work from the browser if you put 'username:pass@' in front of the address?
zoomkat
You may need to search Google for the make of your web cam to see if there is detailed info on its operation or a user's manual. Make sure you are doing the base64 encoding properly like below (the bottom links have encode and decode for checking). I use something similar to update my no-ip account.
bXl1c2VybmFtZTpteXBhc3N3b3Jk
http://www.opinionatedgeek.com/dotnet/tools/base64encode/
http://www.opinionatedgeek.com/DotNet/Tools/Base64Decode/default.aspx
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
AJoao
thank you everybody by to dispend your time with me!
Hi already did find a solution for my project. It is the following:
On Chrome:
http://username:pass@192.168.1.244:81/video/livesp.asp. It is Ok!
On Firefox it is necessary to confirm the login.
On IE dont work!
On Arduino-WebClient:
    client.print("GET /Authorization: Basic ");
    client.print("dXNlcm5hbWU6cGFzcw==@192.168.1.244:81");
    client.println("/video/livesp.asp HTTP/1.1");
    client.println();
  else {
It is OK!
See this link: http://www.httpwatch.com/httpgallery/authentication
And this link to converter Base64 online: http://www.motobit.com/util/base64-decoder-encoder.asp
See this link too: http://en.wikipedia.org/wiki/Basic_access_authentication#Client_side
But my project dont is complete yet! But already it is a begin...
I will go to thinging about that...
Best regards,
AJoao
