Topic: SOLVED Unexplainable?!? (bad connections, my bad) (Read 3544 times) previous topic - next topic
Grumpy_Mike
No problem.
But if you have no decoupling caps on the board you still need them for stability and noise immunity. Yes connect them like you showed or better still directly across the pins of the chip with as short a wire lead as possible. A ceramic is much better than a tant, as it cuts out higher frequencies.
