Topic: HELP!!!! new to programming (Read 3180 times) previous topic - next topic
mrburnette
Apologies ... I assumed you were talking about the PC end.
Your buttons go to pins on the Arduino that are defined in statements like this
Code: [Select]
  pinMode(14, INPUT);  //enter
  pinMode(15, INPUT);  //up
  pinMode(16, INPUT);  //down
  pinMode(17, INPUT);  //left
  pinMode(18, INPUT);  //right
  //other setup code...
The 14 - 18 are Arduino pins NOT physical numbers.
Buttons are wired: http://arduino.cc/en/Tutorial/Button
craigcurtin
#16
Aug 01, 2013, 02:03 am Last Edit: Aug 01, 2013, 02:05 am by craigcurtin Reason: 1
Code: [Select]
And you really want to look at some of the Debounce code options to ensure you are getting what you think you are getting from each of the buttons.
Have a look in the examples under digital for Button and Debounce
Craig
GoForSmoke
Code: [Select]
One reason to learn the Control Examples in the IDE before writing your own code is to learn about arrays and for-loops.
Code: [Select]
#define KEYS 5;
byte keyPin[ KEYS ] = { 14, 15, 16, 17, 18 }; // easy to change once here, easy to use below
enum { enter, up, down, left, right } key; // learn about these later, just be aware
  for ( byte i = 0; i < KEYS; i++ ) // i will not exist outside of this for loop
    pinMode( keyPin[ i ], INPUT );
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
3) http://gammon.com.au/interrupts
