Topic: Do I need a resistor for each LED? (Read 6166 times) previous topic - next topic
runaway_pancake
Most modern DMM have both separate resistor shunt(s) and separate fuse(s) for typically the two different current jacks.
Lefty
I have two of the same Fluke (70-series) meter.  I cleared the fuse in one of them (the mA) and replaced it with an "equivalent" rated fuse.  Then the readings were off.  I swapped the fuse with the other which still had its original and it was better.  I placed the "equiv" in the other meter and then it was off.
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
retrolefty
Lefty
If you check your Fluke user's manual I suspect it says there are no 'equivalent' fuses for the meter and to only use fluke 'approved' fuses designed for the model in question. They are hellishly expensive also.
Lefty
polymorph
Sorry, I have a handful of meters with no current measurement. And before that, I had meters that had relatively high resistance on the lower current ranges. With 0.1 ohms (typo said 0.7 ohm) on the 200.0mV scale, I can measure down to 1mA.
Probably not an issue with newer DMMs with lower current shunt resistors.
Steve Greenfield AE7HD
Drawing Schematics: tinyurl.com/23mo9pf - tinyurl.com/o97ysyx - https://tinyurl.com/Technote8
Multitasking: forum.arduino.cc/index.php?topic=223286.0
gammon.com.au/blink - gammon.com.au/serial - gammon.com.au/interrupts
