Topic: playing tones based on micros() (Read 15994 times) previous topic - next topic
CrossRoads
Jul 28, 2013, 09:19 am Last Edit: Jul 28, 2013, 09:21 am by CrossRoads Reason: 1
I've got some code running, using a 1284P to allow 13 push buttons and have 13 tones out.
(piezo thread elsewhere got me going on this)
(easily scaled back to 8 & 8 on an UNO).
It's sort of "ultimate blink without delay" if you will.
What I am seeing is long bursts of ~40KHz output for as long as 11 seconds before the output settles down to the intended frequency.
I was thinking that it is taking a long time for the equivalent of "previousMicros" to catch up & get back in sync with the intended frequency.
Any thoughts on how to fix that?
This is the code that oscillates:
Code: [Select]
 /* Check if key for note C4 is pressed, key0  */
 if ((portDkeys & 0x04) == 0){ // key is pressed D2 -> A2
   // see if time to change hi to lo, or lo to hi
   if ( (currentTime - changeTime[0])>=noteArray[48]){    // <<< seems like the value in changeTime[0]
                                                     // <<< needs to catch up when a note starts
     changeTime[0] = changeTime[0] + noteArray[48];
     PINA=0x04;  // toggle output bit
This didn't fix it, just stopped the output altogether
Code: [Select]
if (keyActive[0] == 0){changeTime[0] = currentTime;}
     keyActive[0]=1;
 else{keyActive[0]=0;}
And the entire file is attached.
Osgeld
#1
Jul 28, 2013, 09:26 am Last Edit: Jul 28, 2013, 09:27 am by Osgeld Reason: 1
no thoughts to fix it, but I have noticed it for a very long time trying to modulate wav files using it ... since 0.18
I named it the little squawk, for my playing around I squelched it some using a low pass filter, but its a ghetto way of doing it
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
CrossRoads
Ooh! Think I might have it:
Code: [Select]
    if (keyActive[0]==0){
      keyActive[0] = 1;
   if ( (currentTime - changeTime[0])>=noteArray[48]){ // time for a period toggle?
     changeTime[0] = changeTime[0] + noteArray[48];    // setup time for the next toggle
     PINA=0x04;  // write a 1 to PINx toggles an output bit - NickGammon to the rescue again!
 else{keyActive[0] = 0;}
Adding it in to more keys ...
CrossRoads
I think that did it  XD
Suppose I could connect the logic analyzer next and see if multiple outputs will mess anything up ...
CrossRoads
#4
Jul 29, 2013, 12:26 am Last Edit: Jul 29, 2013, 12:28 am by CrossRoads Reason: 1
Completed code, pic of prototype, schematic.
(cap on the power supply rail didn't make it onto the schematic tho, nor did the FTDI module off to the side of the 1284 board)
I connected to an amplified computer speaker. The sounds do not interfere with each other at all. I only had 8 switches, so I connected c-d-e-f-g-a-b-c. Tried pressing up to all 8 at once, did not hear any frequency fluctuation at all.  C4 and C5 sound good together, no "beat frequency at all, and also sounds very in tune with wife's baby grand piano.
CrossRoads
I could see several of these to make up a keyboard with as many octaves as you want.
I used 26 of 32 IO, so add some more notes or use the extra pins for other effects to be written later.
nickgammon
Sounds pretty cool. Maybe make a YouTube video showing it off?
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
CrossRoads
#7
Jul 30, 2013, 12:27 am Last Edit: Nov 23, 2016, 06:18 pm by CrossRoads
Short video of me sort of hacking out a tune!
https://www.youtube.com/watch?v=4c8idXN4Pg0
[edit 11/23/2016 - link fixed, seems youtube changed cut & paste formats?]
nickgammon
Seems to work pretty well. Well done!
larryd
No technical PMs.
The last thing you did is where you should start looking.
GoForSmoke
Quote
What returns that pin to LOW? Toggle would take:
      PINA ^= 0x04;
Um confused.
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
3) http://gammon.com.au/interrupts
Your sketch can sense ongoing process events in time.
Your sketch can make events to control it over time.
nickgammon
Datasheet page 77:
Quote
13.2.2 Toggling the Pin
Writing a logic one to PINxn toggles the value of PORTxn, independent on the value of DDRxn. Note that the SBI instruction can be used to toggle one single bit in a port.
Quote
Toggle would take:
      PINA ^= 0x04;
You are thinking of PORTA.
GoForSmoke
What a neat little speed trick!
CrossRoads
Yep, those guys at Atmel are sharp. Nick Gammon is pretty sharp too for finding that in the datasheet!
nickgammon
I can't really take the credit. Someone else put me up to it. But it is a nice trick :)
