Topic: Two Potentiometer Arduino to xbee to xbee to Arduino to two Led's (Read 9858 times) previous topic - next topic
BenBenBen
I would like to know how to read the serialin data,  so I can make the led's ramp up from 0 to 253.
The data I am reading on the rx side of the serial Monitor is this
(Sensor 1 = 255202255  Sensor 2 = 2550254  Sensor 1 = 255202255  Sensor 2 = 2550254)
As I ramp up the pot, the data moves from 0 to 202 on the Sensor = 1.
Here is the programs I am working with.
TX
Code: [Select]
int analogValue2, analogValue5, val2, val5;
// start serial port at 19200 bps
Serial.begin(19200);
// read analog input
analogValue2 = analogRead(0);
analogValue5 = analogRead(4);
// remap values
val2 = map(analogValue2, 0, 1023, 0, 253);  // 254 and 255 for SYNC
val5 = map(analogValue5, 0, 1023, 0, 253);
Serial.write(254); //SYNC char
Serial.write(val2);
Serial.write(255); //SYNC char
Serial.write(val5);
delay(150);
RX
Code: [Select]
byte incomingByte, sensor1, sensor2;
Serial.println("Ready!");
// led pins
pinMode (10, OUTPUT);
pinMode (11, OUTPUT);
if (Serial.available()) {   // are there any bytes available on the serial port ???
// assign bytes to the var 'incomingByte'
incomingByte = Serial.read();
Serial.print(int(incomingByte));
// from now on is pretty clear I guess   :)
if ((int(incomingByte) == 254)) {
sensor1 = Serial.read();
Serial.print("  Sensor 1 = ");
Serial.print(int(sensor1));
if ((int(incomingByte) == 255)) {
sensor2 = Serial.read();
Serial.print("  Sensor 2 = ");
Serial.print(int(sensor2));
analogWrite (10, sensor1);
analogWrite (11, sensor2);
PaulS
Serial data is NOT guaranteed to be delivered. What are you going to do when one of the bytes gets lost?
You seem to have a misunderstanding of what data each sensor sends. Each sends ONE byte (not two or three) per iteration of loop.
Code: [Select]
Serial.available() returns the number of bytes available, not TRUE or FALSE. Do NOT use it like it returned TRUE or FALSE.
What IS your problem?
BenBenBen
#2
Jul 29, 2013, 03:11 am Last Edit: Jul 29, 2013, 03:16 am by BenBenBen Reason: 1
(What IS your problem)  ((You PaulS,  all your good at Is Ridiculing people.  Do you really know anything....)
Last I looked It's said Programming Questions.   If I know it all like you say you do,  I wouldn't be asking dead
beats like you.........
I am asking for help.........not people like you, A ass.
zoomkat
I made some servo/pot test code below that might be of interest for the rx side. The value is represented by ascii characters, the addressed servo is identified by a letter, and each data packet is delimited by a comma. On the tx side the packet should be easy to generate with the same properties.
Code: [Select]
//zoomkat 11-22-12 simple delimited ',' string parse
//from serial port input (via serial monitor)
//and print result out serial port
//multi servos added
String readString;
#include <Servo.h>
Servo myservoa, myservob, myservoc, myservod;  // create servo object to control a servo
  //myservoa.writeMicroseconds(1500); //set initial servo position if desired
  myservoa.attach(6);  //the pin for the servoa control
  myservob.attach(7);  //the pin for the servob control
  myservoc.attach(8);  //the pin for the servoc control
  myservod.attach(9);  //the pin for the servod control
  Serial.println("multi-servo-delimit-test-dual-input-11-22-12"); // so I can keep track of what is loaded
  //expect single strings like 700a, or 1500c, or 2000d,
  //or like 30c, or 90a, or 180d,
  //or combined like 30c,180b,70a,120d,
    char c = Serial.read();  //gets one byte from serial buffer
    if (c == ',') {
      if (readString.length() >1) {
        Serial.println(readString); //prints string to serial port out
        int n = readString.toInt();  //convert readString into a number
        // auto select appropriate value, copied from someone elses code.
        if(n >= 500)
          Serial.print("writing Microseconds: ");
          Serial.println(n);
          if(readString.indexOf('a') >0) myservoa.writeMicroseconds(n);
          if(readString.indexOf('b') >0) myservob.writeMicroseconds(n);
          if(readString.indexOf('c') >0) myservoc.writeMicroseconds(n);
          if(readString.indexOf('d') >0) myservod.writeMicroseconds(n);
          Serial.print("writing Angle: ");
          Serial.println(n);
          if(readString.indexOf('a') >0) myservoa.write(n);
          if(readString.indexOf('b') >0) myservob.write(n);
          if(readString.indexOf('c') >0) myservoc.write(n);
          if(readString.indexOf('d') >0) myservod.write(n);
         readString=""; //clears variable for new input
    else {
      readString += c; //makes the string readString
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
PaulS
Quote
So, they do something. You have not described what they do.
You want them to do something. You have not explained what that is.
Clearly, though, what they do and what you want are not the same things. If they were, you're whiny little rant would have been unnecessary and we wouldn't have had to hear from you.
So, I'll ask again. What is your problem? What do you need help with?
BenBenBen
Here is the Link, with code, that I  trying to get to work.  (One pot to Arduino to xbee to xbee to Arduino to Led) I did get to work.
I just want to see if I can get the (Two pot to Arduino to xbee to xbee to Arduino to two Led's).  It is working in the movie,  but what is
it missing...
http://lab.guilhermemartins.net/2008/12/24/serial-comunication-between-arduinos-with-wire-wireless/
One Pot
Code: [Select]
// SENDER
int analogValue5, val5;
// Serial port enable
// read analog pin 5
analogValue5 = analogRead(0);
// remap values from the analogValue5 variable to 0 / 255
val5 = map(analogValue5, 0, 1023, 0, 255);
// send the value to the serial port
Serial.write(val5);
One Pot
Code: [Select]
// RECIEVER
byte incomingByte;
// declare pin 11 as output, this is the LED
// if there is bytes available coming from the serial port
// set the values to the 'incomingByte' variable
// write the value to the pin 11
analogWrite(11, int(incomingByte));
BenBenBen
I had 77 people look at my Forum,  and only two of them people could kind of help me.
Where can I read about this,  sending serial data from one xbee to xbee,  or readString of data?
Or maybe you people don't know......
zoomkat
What have you done so far besides apparently posting somebody else's code?
PaulS
Quote
I've asked twice now for you to explain what the problem is. Each time, you've chosen, instead, to make it somehow our fault that your code and your expectations don't align.
I'd suggest that you get over it. The code IS working correctly. Whatever it is doing, it is exactly what it is supposed to do. Therefore, the problem is that your expectations are wrong.
But, until you explain what they are, and how what the code actually does does not meet those expectations, all you can do is whine. But, not here.
BenBenBen
#9
Aug 01, 2013, 04:07 am Last Edit: Aug 01, 2013, 04:12 am by BenBenBen Reason: 1
I think what is the problem is.  In this line of code on the rx side the led 10 and Led 11, is turned on by the first byte, and stays on for the 254 and 255. I need to read the sec. byte and then send it to the (analogWrite (10, sensor1); and analogWrite (11, sensor2);
That is what I think is going on.  But I don't know how to read the sec. byte,  should say, the code.
Is there A way to say in code (sensor1 = Serial.read(); sec.byte only)
Code: [Select]
runaway_pancake
I don't know, maybe I shouldn't jump in, but how does the receiver "know" whether the data it gets is for 'sensor1' or 'sensor2', or doesn't that matter?  A byte is a byte; well, here's a byte, I guess - go for it.
Did you want to have a conversation or did you just want to get this thing done, over with?
Anyway, wouldn't a "header" set things up like?
With GPS, a receiver sketch waits for a particular sentence's header; so cued, it then buffers and can intelligently parse (work with) the data accordingly.
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
zoomkat
About as simple as it gets for two arduinos with appropriately connected tx/rx/gnd serial connections. Put the below code on both arduinos. Send on and off to the tx arduino via the serial monitor, and the LED on the rx arduino should follow the commands.
Code: [Select]
// zoomkat 8-6-10 serial I/O string test
// type a string in serial monitor. then send or enter
// for IDE 0019 and later
int ledPin = 13;
String readString;
  pinMode(ledPin, OUTPUT);
  Serial.println("serial on/off test 0021"); // so I can keep track
  while (Serial.available()) {
    delay(3);
    readString += c;
  if (readString.length() >0) {
    //Serial.println(readString);
    Serial.print(readString);
    if (readString == "on")
      digitalWrite(ledPin, HIGH);
    if (readString == "off")
      digitalWrite(ledPin, LOW);
    readString="";
BenBenBen
So how do I have the rx side of the Arduino read the input of the two pot's.  With the code you sent me?
I wish I could look this up and read on how to fix my problem,  So I would stop asking on here.
RX
Code: [Select]
// led pins
runaway_pancake
#13
Aug 02, 2013, 03:32 am Last Edit: Aug 02, 2013, 05:25 am by Runaway Pancake Reason: 1
I guess 254 (oxfe) is your header for sensor1 and 255 (0xff) is for sensor2?
(Reliable?)
If you send 254 (0xfe) followed by sensor1 data then sensor2 data then...
Code: [Select]
 if (Serial.available() > 0)
   if (incomingByte == 254)
      Serial.print("S1 = ");
      Serial.println(sensor1,DEC);
      Serial.print("S2 = ");
      Serial.println(sensor2,DEC);
There is plenty to read and take advantage of, but what there is doesn't match your needs point-for-point; it's presented as concepts you have to integrate and apply to your situation, as I'm likely doing imperfectly.
[Where's the conversation?]
GoForSmoke
Code: [Select]
Gee Paul, calm down. 0 bytes = 0 which also = FALSE while 1 or more is non-zero = TRUE.
That's the test that I use and it has never failed me.
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
3) http://gammon.com.au/interrupts
Tasking: techniques make the trees, the sketch is the woods.
See the woods and the trees, comment both.
