Topic: nokia 5110 sketch (Read 4324 times) previous topic - next topic
desmondttm123
hello, i tried uploading a nokia 5110 sketch that displays time, but the display has a very dark back ground similar to the problem here http://forum.arduino.cc/index.php/topic,135964.0.html. however i dont understand how to solve it. what do i have to change in the sketch to tune the display?
desmondttm123
i realised by varying the resistance of power, will get clearer imaging
Riva
What library are you using and you will also need to post your sketch. Some libraries allow you to set the contrast level.
desmondttm123
hi, the sketch is as bellow
#define PIN_SCE   7
#define PIN_RESET 6
#define PIN_DC    5
#define PIN_SDIN  4
#define PIN_SCLK  3
#define LCD_CMD   0
#define LCD_C     LOW
#define LCD_D     HIGH
#define LCD_X     84
#define LCD_Y     48
static const byte Digits[][4][18] =
  0xF0, 0xF8, 0xF4, 0xEE, 0x1F, 0x1F, 0x1F, 0x1F, 0x1F, 0x1F, 0x1F, 0x1F, 0x0E, 0x04, 0x00, 0x00, 0x00 },
   { 0x1F, 0x3F, 0x7F, 0xBF, 0xDF, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xC0, 0x80, 0x00, 0x00, 0x00 },
   { 0xFC, 0xFE, 0xFF, 0xFE, 0xFD, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0xFD, 0xFE, 0xFF, 0xFE, 0xFC },
   { 0x03, 0x07, 0x0F, 0x17, 0x3B, 0x7C, 0x7C, 0x7C, 0x7C, 0x7C, 0x7C, 0x7C, 0x7C, 0x3B, 0x17, 0x0F, 0x07, 0x03 },
   { 0x00, 0x00, 0x00, 0x04, 0x0E, 0x1F, 0x1F, 0x1F, 0x1F, 0x1F, 0x1F, 0x1F, 0x1F, 0xEE, 0xF4, 0xF8, 0xF0, 0xE0 },
   { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x3F, 0x7F, 0x3F, 0x1F },
   { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFC, 0xFE, 0xFF, 0xFE, 0xFC },
   { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x07, 0x0F, 0x07, 0x03 },
   { 0xE0, 0xF0, 0xF8, 0xF4, 0xEE, 0x1F, 0x1F, 0x1F, 0x1F, 0x1F, 0x1F, 0x1F, 0x1F, 0xEE, 0xF4, 0xF8, 0xF0, 0xE0 },
   { 0x1F, 0x3F, 0x7F, 0xBF, 0xDF, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xDF, 0xBF, 0x7F, 0x3F, 0x1F },
   { 0x00, 0x00, 0x00, 0x00, 0x01, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0xFD, 0xFE, 0xFF, 0xFE, 0xFC },
   { 0x00, 0x00, 0x00, 0x10, 0x38, 0x7C, 0x7C, 0x7C, 0x7C, 0x7C, 0x7C, 0x7C, 0x7C, 0x3B, 0x17, 0x0F, 0x07, 0x03 },
static const byte SecondIndicator[4] =
 0x00, 0x07, 0x70, 0x00
void LcdInitialise(void)
 pinMode(PIN_SCE, OUTPUT);
 pinMode(PIN_RESET, OUTPUT);
 pinMode(PIN_DC, OUTPUT);
 pinMode(PIN_SDIN, OUTPUT);
 pinMode(PIN_SCLK, OUTPUT);
 digitalWrite(PIN_RESET, LOW);
 digitalWrite(PIN_RESET, HIGH);
 LcdWrite( LCD_CMD, 0x21 ); // LCD Extended Commands.
 LcdWrite( LCD_CMD, 0xC8 ); // Set LCD Vop (Contrast)
 LcdWrite( LCD_CMD, 0x06 ); // Set Temp coefficent
 LcdWrite( LCD_CMD, 0x14 ); // LCD bias mode 1:48
 LcdWrite( LCD_CMD, 0x20 ); // LCD Standard Commands.
 LcdWrite( LCD_CMD, 0x0C ); // LCD in normal mode. 0x0d for inverse
void LcdWrite(byte dc, byte data)
 digitalWrite(PIN_DC, dc);
 digitalWrite(PIN_SCE, LOW);
 shiftOut(PIN_SDIN, PIN_SCLK, MSBFIRST, data);
 digitalWrite(PIN_SCE, HIGH);
void LcdClear(void)
 for (int index = 0; index < LCD_X * LCD_Y / 8; index++)
   LcdWrite(LCD_D, 0x00);
void Spacer()
void DisplayTime(byte hour, byte minutes, byte seconds)
 byte components[4] =
   (byte)(hour / 10),
   (byte)(hour % 10),
   (byte)(minutes / 10),
   (byte)(minutes % 10)
 for(byte row = 0; row < 4; row++)
   LcdWrite(LCD_C, 0x80 | 0);
   LcdWrite(LCD_C, 0x40 | row);
   for(byte digit = 0; digit < 4; digit++)
     for(byte col = 0; col < 18; col++)
       LcdWrite(LCD_D, Digits[components[digit]][row][col]);
     Spacer();
     // Display second indicator after the second digit
     if(digit == 1)
       DisplaySecondIndicator(row, seconds & 0x01);
 DrawSecondsBar(seconds);
void DisplaySecondIndicator(byte row, boolean show)
 for(int secondIndicatorSegment = 0; secondIndicatorSegment < 3; secondIndicatorSegment++)
   if(show)
     LcdWrite(LCD_D, SecondIndicator[row]);
   else // clear
 Spacer();
void DrawSecondsBar(byte seconds)
 // Position the pointer
 LcdWrite(LCD_C, 0x80 | 0x0b);
 LcdWrite(LCD_C, 0x44);
 // Draw the left side of the progress bar box
 LcdWrite(LCD_D, 0xF0);
 for(byte i = 0; i < 59; i++)
   if(i < seconds)
     LcdWrite(LCD_D, 0x90);
 // Draw the right side of the progress bar box
byte tcnt2;
unsigned long time = 0; // 86390000;
void setup(void)
 SetupInterrupt();
 InitializeDisplay();
// Credits for the interrupt setup routine:
// http://popdevelop.com/2010/04/mastering-timer-interrupts-on-the-arduino/
void SetupInterrupt()
 /* First disable the timer overflow interrupt while we're configuring */
 TIMSK2 &= ~(1<<TOIE2);
 /* Configure timer2 in normal mode (pure counting, no PWM etc.) */
 TCCR2A &= ~((1<<WGM21) | (1<<WGM20));
 TCCR2B &= ~(1<<WGM22);
 /* Select clock source: internal I/O clock */
 ASSR &= ~(1<<AS2);
 /* Disable Compare Match A interrupt enable (only want overflow) */
 TIMSK2 &= ~(1<<OCIE2A);
 /* Now configure the prescaler to CPU clock divided by 128 */
 TCCR2B |= (1<<CS22)  | (1<<CS20); // Set bits
 TCCR2B &= ~(1<<CS21);             // Clear bit
 /* We need to calculate a proper value to load the timer counter.
  * The following loads the value 131 into the Timer 2 counter register
  * The math behind this is:
  * (CPU frequency) / (prescaler value) = 125000 Hz = 8us.
  * (desired period) / 8us = 125.
  * MAX(uint8) + 1 - 125 = 131;
 /* Save value globally for later reload in ISR */
 tcnt2 = 131;
 /* Finally load end enable the timer */
 TCNT2 = tcnt2;
 TIMSK2 |= (1<<TOIE2);
void InitializeDisplay()
 LcdInitialise();
 LcdClear();
* Install the Interrupt Service Routine (ISR) for Timer2 overflow.
* This is normally done by writing the address of the ISR in the
* interrupt vector table but conveniently done by using ISR()  */
ISR(TIMER2_OVF_vect) {
 /* Reload the timer */
 TCNT2 = tcnt2;
 time++;
 time = time % 86400000;
void loop(void)
 unsigned long t = (unsigned long)(time/1000);
 DisplayTime((byte)(t / 3600), (byte)((t / 60) % 60), (byte)(t % 60));
will be great if can change contrast via sketch, dont have to use resistor
mrburnette
Change the software contrast constant.... The last Hex byte runs 0 (light) to F (dark)
Nick_Pyner
After that thread you allude to I was going to write up a child's guide to the 5110 but I'm afraid I never got round to it, chiefly because I have confined it to text.
The best demo of the 5110 sans library I know of is Stewart Little's but using his settings in the other programmes does not completely solve the problem.
http://blog.stuartlewis.com/2011/02/12/scrolling-text-with-an-arduino-and-nokia-5110-screen/
IF you intend to use the 5110 for text output, I suggest you ditch all that stuff and use the Philips PCD8544 library. Unfortunately the pin-call is in the library, and you might have to open it up and  change it for your display, but this is a one-off.
I find the 5110 ideal for data-logging. It's great advantage is in having six lines of text.
You might find the following handy
http://www.carlos-rodrigues.com/projects/pcd8544/
http://ianlangelectronic.webeden.co.uk/#/lcd-module-0/4569058582
Riva
The AdaFruit version of the PCD8544 library allows you to specify the connection pins in your sketch when initializing the display, it also allows you to adjust contrast from your sketch.
Nick_Pyner
Thanks
I think those blue background lights are the kiss of death but they might be redeemed with some contrast control.
NP
