What is the application?
You should start with the behavior that is needed. Lets suppose this is a small robot that should avoid bumping into a wall.
The rules:
- < 1.5v full speed ahead
- 1.5v - 2.5v slow down
2.8v stop and turn
Of course I just made it up. The point is you may not need any conversion depending on the application.
If you really need distance you can use an algebraic equation or a lookup table with interpolation. I prefer lookup tables, which can be setup directly from test measurements. Simple interpolation will improve accuracy if needed.
