Topic: SOLVED - Cannot interface with the Due as a COM port (Read 799 times) previous topic - next topic
jtw11
Jul 31, 2013, 10:10 pm Last Edit: Jul 31, 2013, 11:24 pm by jtw11 Reason: 1
Hi all,
I'm building a Windows application to interface with a board I'm working on that uses a SAM3X8E, same as the Due - and am just starting on the programming between Windows and the board.
I'm using a Due to test this interface, however - when I connect the Due (either USB port), it doesn't show up as a COM port in the Device Manager - just as 'Arduino Due Prog. Port' under 'Other Devices' - and the Visual Basic code I've found references COM ports. If however I use my Uno, it shows up as COM 4 and the VB code works with this.
I've written the software on the Due to take a 0 as LED off, 1 as LED on, 2 and LED flash - and I've got three buttons in my VB program, that work perfectly using the Uno.
Any ideas how to either get the Due to show up connected to a COM port, or else how to interface Visual Basic with the Due?
Imports System.IO
Imports System.IO.Ports
Imports System.Threading
Public Class Form1
   Shared _continue As Boolean
   Shared _serialPort As SerialPort
   Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
       SerialPort1.Close()
       SerialPort1.PortName = "com4"
       SerialPort1.BaudRate = 9600
       SerialPort1.DataBits = 8
       SerialPort1.Parity = Parity.None
       SerialPort1.StopBits = StopBits.One
       SerialPort1.Handshake = Handshake.None
       SerialPort1.Encoding = System.Text.Encoding.Default
   End Sub
   Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
       SerialPort1.Open()
       SerialPort1.Write("1")
       SerialPort1.Close()
   End Sub
   Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
       SerialPort1.Open()
       SerialPort1.Write("0")
       SerialPort1.Close()
   End Sub
   Private Sub Button3_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button3.Click
       SerialPort1.Open()
       SerialPort1.Write("2")
       SerialPort1.Close()
   End Sub
End Class
Many thanks in advance!
EDIT - Oops, I just hadn't installed the drivers for the Due yet...
f.schiano
Just keep in mind, for the future, if you plan to use Linux that for that you donĀ“t need any driver.
Bye
jtw11
Yep - I also use OSX, and didn't require any drivers.
A slightly off but on topic question here then I suppose, what exactly do the drivers tell the PC? Why does the Due not appear connected to a COM port prior to installation the drivers?
