Topic: remote control and delay problem (Read 961 times) previous topic - next topic
brraaq
I want to run for 2 minutes and shuts off for 4 minutes I add function to stop by remote control but the problem is that the remote command is not received until the end of the delay
help in modifying the code
Code: [Select]
#include <IRremote.h>
int RECV_PIN = 2;
IRrecv irrecv(RECV_PIN);
decode_results results;
int buttonState = 0;
int lastpressed = 0;
int i = 1;
  irrecv.enableIRIn();
pinMode(13, OUTPUT);
unsigned long codeValue;
  if (irrecv.decode(&results) ) {
Serial.println (results.value, DEC) ;
  codeValue = results.value;
      irrecv.resume();
   if (codeValue == 83579055){
   i = 1;
   if (codeValue == 83570895){
   i = 0;
if (i == 1){
   digitalWrite(13, HIGH);
   delay(120000);
   digitalWrite(13, LOW);
   delay(240000);
delay(10);
Arrch
BlinkWithoutDelay example. Learn it. Live it. Love it.
CrossRoads
Rewrite it following blink without delay methodology.
brraaq
Arrch
I tried and I didn't succeed
That's too bad. We could probably help if we saw what you tried.
LarryD
Try again and ask for us for help.
No technical PMs.
The last thing you did is where you should start looking.
brraaq
Code: [Select]
int RECV_PIN = 2;
int i = 1;
long time2 = 120000;
long time4 = 240000;
      irrecv.resume();
   i = 1;
   i = 0;
if (i == 1){
   unsigned long time2 = millis();
   unsigned long time4 = millis();
delay(10);
brraaq
Arrch
All you are doing is recording the time, you're not doing anything with it. Notice how in the BlinkWithoutDelay example, there is an if statement involving the previous recorded time?
brraaq
now it's work but with same time for on and off
thank you and check the code
Code: [Select]
int RECV_PIN = 2;
int i = 1;
long previousMillis = 0;
long interval = 120000;
int ledState = HIGH;
const int ledPin =  13;
      irrecv.resume();
   i = 1;
   i = 0;
   if ( i == 1 ) {
       digitalWrite(ledPin, ledState);
  if(currentMillis - previousMillis > interval) {
    // save the last time you blinked the LED
    if (ledState == LOW)
      ledState = HIGH;
      ledState = LOW;
    // set the LED with the ledState of the variable:
     digitalWrite(ledPin, LOW);
delay(10);
Arrch
So when you turn it on, set interval to whatever the off interval is. When you turn it off, set interval to whatever the on interval is.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
