Topic: DS18B20 & Arduino Uno in Proteus Isis (Read 8806 times) previous topic - next topic
tweety
Aug 01, 2013, 10:38 am Last Edit: Aug 01, 2013, 10:51 am by tweety Reason: 1
Hello.
I'm trying to simulate the use of a ds18b20 in isis.
I'm working with arduino 1.0.5. and I downloaded the latest OneWire library.
In my atmega328p, I put the sample code DS18x20_Temperature just with just replacing the ds pin from 10 to 2.
And it's not working : No more adresses.
Here is my schema.
What's going wrong ?
Thanks.
Edit : it's working using d10 pin.  Why not whith d2 ?
robtillaart
because the pin is not defined as INPUT/OUTPUT?
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
tweety
No.  The lcd is connected but not used by the atmega.  Only the sample code for ds18b20.
DS connected to pin d2 - not working.
DS connected to pin d10 (and pin d10 also connected to lcd) - working.
Pin d10 disconnected from lcd - not working.
Now I found the pull-up resistor of the ds is wrong : 4R7 in place of 4K7.
Corrected and ... working.
But if I connect again the pin d10 to ldc, it's not working.
Ok, it's stupid to connect the lcd on the pin.  But if I disconnect the lcd and connect the led (on the bottom right) it's also not working.
So I suppose it's a question of value for the resistor.  But how to calculate it ?
robtillaart
Quote
so pin 10 is connected to both the LCD and the DS18B20. (this is not preferred but opens possibilities ;)
Seems that the LCD has somehow the proper resistor value / behavior
What is the function of the LCD pin connected to Arduino pin 10?
- data pin
- ENable pin
- RW pin
What type of communication does the LCD use?
- Serial
- SPI
- I2C
- parallel (4/8 datalines)
- other?
Rob Tillaart
tweety
Quote
Ok, I know it's stupid ... I tell it in the post above  8)
The pin d10 is connected to the data pin d7 on the lcd and is using parallel 4 bits.
BUT for the moment it is not used ! No code for the lcd in the atmega.  Only for the ds.
robtillaart
Quote
Maybe, maybe not, it would be great if one could use a single pin for 2 different functions.
The closest I did was to use the serial port for 2 different devices (one input one output) but that are two pins.
OK back to the problem.
The LCD pin seems to act as an additional pull up/down resistor. (I assume the LCD is also connected to 5V and GND)
That is confirmed by the fact that if you remove the LCD the DS doesn't work any more.
What is the length of the cable to the DS? this affects the resistor to choose, the longer the cable the smaller the R.
Rob Tillaart
robtillaart
(not related to DS problem)
looking at your schema, pin 13 is also double used - for the LED and the LCD
That might also cause some interference in the future.
Rob Tillaart
tweety
Heu ... I'm only working with isis ....  I'll try with my arduino later.
I agree with you for the pull-up from the lcd.  So I suppose I have to modify the value of the ds pull-up.  But wich value ?
I tried some values but nothing works.
Perhaps for making it more simple, if I disconnect the lcd and connect the led (in place of pin d13).  It's also not working.
ps : for the led connected on d13, there is no problem.  The lcd works fine.  In fact I make like this because it is the way the arduino uno is made (see http://arduino.cc/en/uploads/Main/Arduino_Uno_Rev3-schematic.pdf).
robtillaart
the value of the resistor is 4K7 for short distances. For long distances it depends on the cable used but common values are 2K2 for 10meter (35 feet).
How long is your cable?
Rob Tillaart
tweety
I'm not working with real cables, only working with isis.
robtillaart
what is isis?  (clearly I missed something ;)
Rob Tillaart
robtillaart
so there is a chance that the simulator has a bug ...
Rob Tillaart
tweety
Perhaps, I don't know.  The last test to realize : doing it with the real arduino.
IvoPenkov
#14
Jan 24, 2016, 12:48 pm Last Edit: Jan 24, 2016, 02:45 pm by robtillaart
Hello everyone ,
i know that this topic is  3 years old but i will geive the  answer ,because  from 3 days i try to simlate 3pcs of DS18B20 in proteus - 3 days of hard web search and nothing. The simple answer is that in Proteus ISIS all sensors have a same ID`s like the first one, so to make them different you got to:
1. hit right mouse button over socond sensor (BECAUSE the first one is already unique ROM Number = B8C530)
2. select "EDIT PROPERTIES"   and there will open a window with sensor properties on line 6 "ROM serial number" will be again B8C530  - change the value   like B8C531, next one  can be B8C532......,3,4,5,6 ......
 And you are ready !
   Sorry for my poor english :) greetings for Bulgaria !
Ivo
[moderator: added empty lines for readability]
