Topic: Arduino 1.0.4 IDE freeze for several minutes, frequently (Read 3015 times) previous topic - next topic
falcon74
Currently using Arduino 1.0.4 on a Windows 7 (64-bit) machine (decently powered - Core i5 (quad-core), 6GB RAM). I am using Java SE 1.6.0_45.
The problematic behavior I observed, is very similar to what is mentioned in these very old threads (2011, and some as old has 2009) --
http://forum.arduino.cc/index.php?topic=50826.0
http://forum.arduino.cc/index.php/topic,50986.0.html
http://forum.arduino.cc/index.php/topic,46977.0.html
So, wondering if the problem still does exist in the latest rxtx lib used by Arduino ?
I do have 2 other (apart from Arduino's FTDI one) virtual COM-port drivers installed (but currently, the devices are not plugged-in). The other COM-port drivers are:
  • PL2303HX based TTL-Serial converter
  • USBASP programmer
The problem is quite bothersome. So, should I use the RXTX lib (hacked) mentioned in the solution circa. Feb 2011 ?
falcon74
falcon74
Just to let others know - I didn't find a solution to my problem.
So I ditched Arduino on Windows (at least for now), and moved my dev work to Linux. Works flawlessly.
Having recently discovered Arduino-mk (Makefile based), build workflow, I am happily using Vim (with Arduino aware syntax highlighting) and having a gala time :-)
