Topic: Graphic ST7565 Negative LCD 128x64 (Read 3857 times) previous topic - next topic
JimboJohn
Hi people
I was going to program a Graphic ST7565 Negative LCD 128x64 to display 4 numbers that are read from 4 sensors at each of the 4 corners of the LCD. However, I can't figure out how I can navigate through pixels on the LCD, by looking at the library file. It seems that there are function(s) for it, but I cant figure out which one(s).
Any help will be appreciated :)
robtillaart
Can you post the code you made sofar,
and a link to the library you use
and a link to the datasheet of the LCD if possible.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
JimboJohn
#2
Aug 03, 2013, 08:33 am Last Edit: Aug 03, 2013, 08:36 am by JimboJohn Reason: 1
Here's a link to where I downloaded the library:
https://github.com/adafruit/ST7565-LCD
Here's a link to the datasheet:
http://www.ladyada.net/learn/lcd/TG12864H3-03A%20EN_V1.1.pdf
Also this is the webpage on adafruit website where I found those links. ( I bought the LCD off that website):
http://www.ladyada.net/learn/lcd/st7565.html
I still haven't written any code, because unlike GLCD library pdf file, I couldn't find any good documentations on how the functions work in this LCD model.
I appreciate any hints or help. :D
robtillaart
A quick look shows that there is at least a game of life example that does the some pixel addressing
the .h file shows quite a straight forward interface. it has functions to draw lines and write text etc.
Code: [Select]
void st7565_init(void);
  void begin(uint8_t contrast);
  void st7565_command(uint8_t c);
  void st7565_data(uint8_t c);
  void st7565_set_brightness(uint8_t val);
  void clear_display(void);
  void clear();
  void display();
  void setpixel(uint8_t x, uint8_t y, uint8_t color);
  uint8_t getpixel(uint8_t x, uint8_t y);
  void fillcircle(uint8_t x0, uint8_t y0, uint8_t r,
  uint8_t color);
  void drawcircle(uint8_t x0, uint8_t y0, uint8_t r,
  uint8_t color);
  void drawrect(uint8_t x, uint8_t y, uint8_t w, uint8_t h,
uint8_t color);
  void fillrect(uint8_t x, uint8_t y, uint8_t w, uint8_t h,
uint8_t color);
  void drawline(uint8_t x0, uint8_t y0, uint8_t x1, uint8_t y1,
uint8_t color);
  void drawchar(uint8_t x, uint8_t line, char c);
  void drawstring(uint8_t x, uint8_t line, char *c);
  void drawstring_P(uint8_t x, uint8_t line, const char *c);
  void drawbitmap(uint8_t x, uint8_t y,
  const uint8_t *bitmap, uint8_t w, uint8_t h,
  uint8_t color);
Think it is just time to write some code, I don't have such a display so I cannot test it.
Here is some code that should get you started
Code: (not tested) [Select]
#define BACKLIGHT_LED 10
// don't know how you connect the thing
// pin 9 - Serial data out (SID)
// pin 8 - Serial clock out (SCLK)
// pin 7 - Data/Command select (RS or A0)
// pin 6 - LCD reset (RST)
// pin 5 - LCD chip select (CS)
ST7565 glcd(9, 8, 7, 6, 5);
  Serial.println("Set backlight");
  pinMode(BACKLIGHT_LED, OUTPUT);
  digitalWrite(BACKLIGHT_LED, HIGH);
  glcd.st7565_init();
  glcd.st7565_command(CMD_DISPLAY_ON);
  glcd.st7565_command(CMD_SET_ALLPTS_NORMAL);
  glcd.st7565_set_brightness(0x18);
  glcd.display(); // show splashscreen
  glcd.clear();
  glcd.drawstring(20,20, "hello");
  glcd.drawline(0,0,0,60, 0);
  glcd.drawline(0,0,60,60, 1);
  glcd.drawline(0,60,60,60, 2);
void loop(){};
Rob Tillaart
robtillaart
Rob Tillaart
JimboJohn
Sorry for late reply.
Thanks again for the code. I tried to upload the code and I got this error:
sketch_aug14a.ino: In function 'void drawGabrielsp138()':
sketch_aug14a:55: error: 'st7565_buffer' was not declared in this scope
sketch_aug14a.ino: In function 'void drawGlider()':
sketch_aug14a:67: error: 'st7565_buffer' was not declared in this scope
Then I put this piece of code in and the error was gone:
extern uint8_t st7565_buffer[1024];
However, nothing was displayed on the lcd, even though the code compiled and uploaded successfully.
I will fiddle with it more and let you know of my progress.
JimboJohn
Me again.
The reason it wasnt showing anything was a loose wire...... my baaaaaaad!!!
But, something interesting happens.When i write:
glcd.drawstring(20,20,"hello");
it only displays "h". But when I write:
glcd.drawstring(0,0,"hello");
it displays "hello".
any ideas what could be happening here??
TheCoolest
I will go out on a limp here and assume this is because when you use drawString, the x,y coordinates actually refer to column and row, not a pixel based x,y.
Usually a single character is considered to be 6 pixels wide and 8 pixels in height.
Try something like glcd.drawstring(2,2,"Hello"); and see what happens.
JimboJohn
The fact that it wasn't displaying was a loose wire (clumsy me!!!!! :smiley-sweat:). However, you are correct about it working in column and row system. I have discovered that it does not go over 7 rows and the screen is divided to around 100 columns. each column is as thick as one character.
