Topic: Disconnecting Arduino from the USB and trying to communicate over TX/RX (Read 501 times) previous topic - next topic
nonomus
I am trying to have the arduino continuously send serial data over TX/RX pins. Once I upload my program onto Arduino using the USB, then unplug the USB, will Arduino automatically start transmitting the serial data over its TX/RX pins (assuming its supplied extermal power)?
Thanks.
Caltoa
Do you have the Arduino Uno board ?
The RX (pin 0) and TX (pin 1) are always connected to the usb-serial.
If you connect something else to pin 0 and pin 1, the signals of the usb-serial are overriden, but they are still connected. That is regardless if the Arduino board is powered with the usb plug or not. So you can keep on using the usb to power the Arduino.
zoomkat
I am trying to have the arduino continuously send serial data over TX/RX pins. Once I upload my program onto Arduino using the USB, then unplug the USB, will Arduino automatically start transmitting the serial data over its TX/RX pins (assuming its supplied extermal power)? Thanks.
I would think it would.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
CrossRoads
