Topic: Interesting behavior, what would be the problem? (Read 4028 times) previous topic - next topic
jopiek
Aug 03, 2013, 02:26 pm Last Edit: Aug 03, 2013, 02:31 pm by jopiek Reason: 1
Hi have a bunch of home-made Arduino clones with Atmega328 uC's.
They have an FTDI header and ISP header. It seems to be that I can't generally program them over FTDI, but I can just after I burned the bootloader onto it. Doesn't matter what bootloader I choose. (avrdude: stk500_recv(): programmer is not responding error)
If I upload the bootloader again (via ISP), I can program it again using FTDI, but only once... Of course it doesn't really matter since programming it using ISP works very well, but I use the FTDI for configuration and debugging purposes using the serial port.
johnwasser
Sounds like you didn't implement the Auto Reset hardware properly.
When you load a fresh bootloader it has nothing better to do than sit around waiting for an upload.
Once a sketch has been uploaded the bootloader will only look briefly for an upload after a reset and will then turn control over to your sketch.
To upload without a working Auto Reset you have to use a manual reset.  Hold down the Reset button (if you didn't include that either, short the Reset pin to Ground) until you see the "Binary sketch size:" message on upload.  This should give the bootloader control at just the right time to notice the upload attempt.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
jopiek
That was what I was thinking, I used a 10k resistor and a reset button b.t.w., just like the Pro Mini design actually, I only left out the .1uF capacitor.
Grumpy_Mike
It is the capacitor that makes it work.
Without it you have to press the reset button at exactly the right time.
Hold the reset, down load the code. When it says downloading count to three and release.
jopiek
I thought so (I looked at the datasheet of the pro mini), and soldered a 104 / .1uF capacitor between RST and DTR, but it doesn't seem to work like that either! I use the official Arduino Ethernet FTDI module to test it.
Grumpy_Mike
Quote
Why?
The capacitor should go from DTR to the arduino reset pin.
jopiek
#6
Aug 05, 2013, 03:19 pm Last Edit: Aug 05, 2013, 03:56 pm by jopiek Reason: 1
Well it does (have the cap between the uC Reset and DTR), I abbreviated Reset to RST (but might cause confusion because there is also an RTS of course in a serial port application).
Grumpy_Mike
Quote
Yes it did sorry.
You need to look at the signal with a scope and see what it is doing in that case then.
jopiek
Yups, one of the only options indeed, I will try to! Thanks!!!
