Topic: Bare-bone Leonardo Schematics (Read 700 times) previous topic - next topic
Protoneer
Hi there,
I have developed a general perpose shield that adds an extra ATMega328(info.protoneer.com/2) to your setup. Currently I program the secondary
MCU with the ArduinoISP sketch. This works fine but I would like to add a USB port to it so you can program and send serial commands independently to the secondary MCU shield.
The ATMega32U4 would work well for this and because the Leonardo is based on it,it would add full compatibility for my shield.
What would be the bare minimum components needed to make a board that is Leonardo compatible?
Delta 3D Printer with Auto Bed Leveling - http://www.kickstarter.com/projects/ttstam/openbeam-kossel-pro-a-new-type-of-3d-printer/posts
http://blog.Protoneer.co.nz
Osgeld
here is the schematic
http://arduino.cc/en/uploads/Main/arduino-leonardo-schematic_3b.pdf
I am planning doing this myself, you can remove the extra led's and the power stuff if you plan on only using USB power, maybe L1 which is a ferrite bead to help clean up the analog input voltage, but there is not really that much to it
Protoneer
#2
Aug 04, 2013, 08:00 am Last Edit: Aug 04, 2013, 08:24 am by Protoneer Reason: 1
Yes... there are a bunch that can be removed. Would you be interested in teaming up with me to get this solved?
I have also looked at : http://imall.iteadstudio.com/itaeduino-leonardo.html - Have a look under downloads for the schematics
Its always good to have a few versions of a design to compare... ;)
Protoneer
I have also looked at the Teensy Ver2 schematics and Freetronics Leostick...
http://pjrc.com/teensy/schematic.html
https://github.com/freetronics/LeoStick/blob/master/LeoStick.pdf
The bit that confuses me is that even if they use the same MCU they have their own hardware configurations and don't use the Leonardo setup.
Could that just be a Bootloader thing?
Osgeld
probally, and the teensey has been around longer
