Topic: help needed to connect jlink to due. (Read 4895 times) previous topic - next topic
mm2426
Hello Everyone,
I brought the new arduino due board and I had written a few programs on it. Now I am having the JLink debugger from segger and I want to use it to download programs into the arduino. So first I am trying to read the bootloader from my controller then I will write and transfer programs into it using JLink. I am unable to do this. The JLINK JTAG header is 20Pin to which I had connected the pins from the arduino.I had connected the JTAG Pins as follows:
JLink Pins               Due Pins
VTref(Pin 1)            3.3V Vcc
TDI (Pin 5)              TDI (10 pin Debug Port pin 8)
TMS(Pin 7)              TMS (4 pin Debug Port pin 3)
TCK (Pin 9)             TCK (4 pin Debug Port pin 2)
TDO (Pin 13)           TDO (10 pin Debug Port pin 6)
RESET (Pin 15)         Reset (4 pin Debug Port pin 4)
GND (Pin 4)             GND
So my question is :
Are these connections ok?
Can anyone give me the standard 20 pin JTAG connector pinout?
Is JLink compatible with SAM3X8E?
jtw11
Quote
http://www.jtagtest.com/pinouts/
Quote
I believe so yes, as Atmel's SAM ICE is just a rebranded Segger J Link...
What interface are you trying to connect with? Atmel Studio, SAM-BA?
mm2426
I am using atmel studio 6 to connect. I am able to read the target voltage successfully (It displays 2.8V) but communication fails.
mm2426
#3
Aug 05, 2013, 05:14 pm Last Edit: Aug 05, 2013, 05:19 pm by mm2426 Reason: 1
I think the pinout displayed on jtagtest.com doesn't match with my 20 pin connector. This is the pinout which matches with mine. (I used this pinout first for communication but it was unable to read the target voltage. Now I shifted to this and I read successfully 2.8V).
I think this pinout matches, but it only reads target voltage and does not program.
Pin No      Functions
1              TMS
3              TDI
5              VREF
7              TDO
9              RTCK
11            TCK
13            EMU0
15            RST
17,19,18   N/C
2              TRST
6              KEY
Rest         GND
Palliser
Hello mm2426,
Please, check my following post:
http://forum.arduino.cc/index.php?PHPSESSID=9jqrv277k12k2or0btoftph4l3&topic=134907.msg1014628#msg1014628
You might even discover some answers to your questions. Regards!
mm2426
Finally I was able to program the due board using JTAG. My JLink worked. The problem I think was with the 20 Pin RMC connector. I just removed it and connected wires directly to the JLink and it worked.
Now I am stuck up in writing a simple blinky program for due in atmel studio 6. Can anyone tell where arduino generated its source code files so that I can tweak into it and get started with writing my code? Actually I am trying to find it out but nothing works correctly for me.
