Topic: Interruption work of stepper motor by TFT display (Read 1 time) previous topic - next topic
RMLR
I have 1,8" TFT, ST7735 and I use library Adafruit.
When value print on the screen every second (tft.println), causes stop of stepper motor about 0,3s, but when I delete tft.println every think work good without interruption. The same situation is when I put serial.print instead tft.print, but stepper motor stop for about 0,1s. I didn't find any solution. How to improve?
Code: [Select]
int relay1Pin = 23;   // relay
int relay2Pin = 25;
int relay3Pin = 27;
int relay4Pin = 29;
int m0 = 39;          // stepper
int m1 = 41;
int sleepPin = 47;
const int stepPin = 49;
int dirPin = 51;
#define sclk 76    //TFT
#define mosi 75
#define cs   10
#define dc   9
#define rst  8
int stepPinState = LOW;
long previous1 = 0;
long previous2 = 0;
long previous3 = 0;
long interval = 500;
static byte runStepper = 0;
static byte autoStepper = 0;
long countImpulse = 0;
int lastStepPinState = LOW;
int stepperRev = 0;
int countDistance = 0;
int timer = 0;
#include <Keypad.h>
#include <Adafruit_GFX.h>
#include <Adafruit_ST7735.h>
#include <SPI.h>
Adafruit_ST7735 tft = Adafruit_ST7735(cs, dc, rst);
const byte ROWS = 4;   // four rows
const byte COLS = 4;   // four columns
// define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
    '1','2','3','A'                      }
    '4','5','6','B'                      }
    '7','8','9','C'                      }
    '*','0','#','D'                      }
byte rowPins[ROWS] = {
  22, 24, 26, 28};   // connect to the row pinouts of the keypad
byte colPins[COLS] = {
  30, 32, 34, 36};   // connect to the column pinouts of the keypad
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);   // initialize an instance of class NewKeypad
  pinMode(relay1Pin, OUTPUT);     // relay
  pinMode(relay2Pin, OUTPUT);
  pinMode(relay3Pin, OUTPUT);
  pinMode(relay4Pin, OUTPUT);
  pinMode(m0, OUTPUT);        // stepper
  pinMode(m1, OUTPUT);
  pinMode(sleepPin, OUTPUT);
  pinMode(stepPin, OUTPUT);
  pinMode(dirPin, OUTPUT);
  digitalWrite(m0, LOW);
  digitalWrite(m1, LOW);
  tft.initR(INITR_REDTAB);
  char customKey = customKeypad.getKey();
  if (customKey == '0')             // distance - reset
    countDistance = 0;
  if (customKey == '1')             // relay 1 on
    digitalWrite(relay1Pin,LOW);
  if (customKey == '4')             // relay 1 off
    digitalWrite(relay1Pin,HIGH);
  if (customKey == '2')             // relay 2 on
    digitalWrite(relay2Pin,LOW);
  if (customKey == '5')            // relay 2 off
    digitalWrite(relay2Pin,HIGH);
  if (customKey == '3')             // relay 3 on
    digitalWrite(relay3Pin,LOW);
  if (customKey == '6')            // relay 3 off
    digitalWrite(relay3Pin,HIGH);
  if (customKey == 'A')             // stepper - right direction
    runStepper = 1;
    digitalWrite(sleepPin, HIGH);
    digitalWrite(dirPin, LOW);
  if (customKey == 'B')             // stepper - left direction
    runStepper = 2;
    digitalWrite(dirPin, HIGH);
  if (customKey == 'C')    //stepper stop
    runStepper = 0;
    autoStepper = 0;
    digitalWrite(sleepPin, LOW);
  if (runStepper == 0)             // stepper - stand by off
  if (runStepper >= 1)             // delay for a stepper
    unsigned long current1 = micros();
    if(current1 - previous1 > interval)
      previous1 = current1;
      if (stepPinState == LOW)
        stepPinState = HIGH;
        stepPinState = LOW;
      digitalWrite(stepPin, stepPinState);
  if (customKey == 'D')       // stepper - automatic feed
    autoStepper=1;
  int sensorValue = analogRead(A0);    // read sensor Value
  int currentValue = sensorValue * (3.3 / 1024.0)*100;
  if (currentValue >= 244 &&  autoStepper==1)
    runStepper = 3;
  if (currentValue < 244 && autoStepper==1)
    runStepper = 0;
  countImpulse = 0;
  if (stepPinState != lastStepPinState) // counting steps of stepper
    if (stepPinState == HIGH)
      countImpulse = 1;
      countDistance;
      if (runStepper == 1)
        countDistance = countDistance + 1;
      if (runStepper == 2)
        countDistance = countDistance - 1;
      if (runStepper == 3)
  lastStepPinState = stepPinState;
  stepperRev = (countImpulse*interval*0.54);
  if (autoStepper == 1)
    unsigned long current2 = millis();  // timer
    if(current2 - previous2 > 1000)
      timer++;
      previous2 = current2;
  unsigned long current3 = millis();  // delay for serial monitor
  if(current3 - previous3 > 1000)
    tft.setCursor(50, 0);
    tft.setTextColor(ST7735_WHITE);
    tft.setTextSize(1);
    tft.fillScreen(ST7735_BLACK);
    tft.println(countDistance*0.01);
    previous3 = current3;
TheCoolest
The best solution is to not update the display while you're moving the stepper motor.
Since updating the screen can take a relatively long time (Arduino's are slow, and not multithreaded).
For Serial, you can try to increase the baud rate, but it won't eliminate the problem altogether.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
