Topic: Changing a sketch to work in the UTFT Libary "2.8" LCD display") (Read 5336 times) previous topic - next topic
lewisjoyce
Hey everyone, Ive manged to get my 2.8" LCD TFT display working. and ive set the code ready to merge it with a basic temp and humid sketch DHT11.
But im not sure how to merge the serial.print to GLCD.print as it keeps coming up with errors.
Can anyone help me merge from the temp sketch to the LCD sketch i have prepared to show the temp and humid in the space provided.
Thank you
Temperature sketch
#include "DHT.h"
DHT dht;
  Serial.println();
  Serial.println("Status\tHumidity (%)\tTemperature (C)\t(F)");
  dht.setup(2); // data pin 2
  delay(dht.getMinimumSamplingPeriod());
  float humidity = dht.getHumidity();
  float temperature = dht.getTemperature();
  Serial.print(dht.getStatusString());
  Serial.print("\t");
  Serial.print(humidity, 1);
  Serial.print("\t\t");
  Serial.print(temperature, 1);
  Serial.println(dht.toFahrenheit(temperature), 1);
LCD SKETCH thats needs glcd.print added
#include <UTFT.h>
#include "DHT.h"
DHT dht;
extern uint8_t SmallFont[];
extern uint8_t BigFont[];
extern uint8_t SevenSegNumFont[];
UTFT myGLCD(ITDB28,A5,A4,A3,A2);
  myGLCD.InitLCD();
  myGLCD.clrScr();
    dht.setup(2);
  myGLCD.setColor(0, 255, 0);
  myGLCD.setBackColor(0, 0, 0);
  myGLCD.setFont(BigFont);
  myGLCD.print("TEMPERATURE", CENTER, 2);
  myGLCD.print(" !\"#$%&#", CENTER, 60); ,--- ////temp printed in the ""
  myGLCD.print("HUMIDITY", CENTER, 135);
  myGLCD.print("sdgsdg", CENTER, 180); //// Humid printed in the ""
  while(1) {};
Thanks to anyone that can help :D
PaulS
But, the errors are going to remain a secret? Not if you want help.
lewisjoyce
Ops, sorry i forgot.
Temp_and_humid_LCD_display.ino: In function 'void loop()':
Temp_and_humid_LCD_display:32: error: no matching function for call to 'UTFT::print(const char*)'
C:\Users\mhsec\Desktop\Arduino-1.0.5\Arduino\libraries\UTFT/UTFT.h:140: note: candidates are: void UTFT::print(char*, int, int, int)
C:\Users\mhsec\Desktop\Arduino-1.0.5\Arduino\libraries\UTFT/UTFT.h:141: note:                 void UTFT::print(String, int, int, int)
Temp_and_humid_LCD_display:43: error: no matching function for call to 'UTFT::print(float&, int, int, int)'
and the sketch the error came from.
#include <UTFT.h>
#include "DHT.h"
DHT dht;
  myGLCD.InitLCD();
  myGLCD.clrScr();
    dht.setup(2);
myGLCD.print(dht.getStatusString());
  myGLCD.print(humidity, 1, CENTER, 135); ////temp printed in the ""
  while(1) {};
sorry and thanks :)
PaulS
Is there some part of the error messages that you don't understand? Serial.print() and UTFT.print() are not interchangeable functions. The serial output doesn't care where to print. The UTFT does.
lewisjoyce
But im not using serial.print cause at the moment my other sketch prints to serial,
thats just serial.print(humidity,1);
but when i try to add GLCD:print(humidity, 1, center, 70);
Temp_and_humid_LCD_display:43: error: expected `)' before numeric constant
Temp_and_humid_LCD_display:43: error: no matching function for call to 'UTFT::print(float&, int, int)'
and if i just put
that in to my UTFT sketch and change it to myGLCD.print(dht.getStatusString());
i recieve
Temp_and_humid_LCD_display:34: error: no matching function for call to 'UTFT::print(const char*)'
how do i get it so it prints the temperature on my LCD display.
lewisjoyce
Im guessing i tell it where to print by adding the( , Center, 70)
Please tell me if im going about this the wrong way, im just trying to learn and have no clue :/
PaulS
Sort of. The ", Center, 70" bit does. The () are required for any function call.
The "problem" is that the UTFT class you are using is pretty dumb. It does not know how to print a float. So, you must convert the float to a string first, using dtostrf().
lewisjoyce
Thanks for the reply,
I would have no clue how to do that as i am extremely new to all this.
I would just like it so i can have the temp and humid sensor on my wall.
Can you explain a bit more on how i would to this, it would be much appreciated.
Thank you, and cheers for your help :D
PaulS
Sure. But, so can google. And google is endlessly patient about providing examples.
Getting other people to write your code is not how to correct that situation.
lewisjoyce
hmm seem to be stuck again :/
#include <UTFT.h>
#include "DHT.h"
DHT dht;
float h = dht.getHumidity();
  float t = dht.getTemperature();
char tempF[6];
dtostrf(t, 6 2, tempF);
  myGLCD.InitLCD();
  myGLCD.clrScr();
    dht.setup(2);
    myGLCD.print(h, 1), CENTER, 70);
  while(1) {};
doc_norway
Another solution would be to try reading the manual (included in the UTFT download) where one can find useful information, like how to print floats with printNumF()...
/Henning
PaulS
Well, the solution is obvious. Or, it might be if you described what your problem is now.
