Topic: setting PWM Counter and registers yields odd behavior (Read 889 times) previous topic - next topic
eddiea6987
Aug 08, 2013, 05:19 am Last Edit: Aug 08, 2013, 05:21 am by eddiea6987 Reason: 1
tonights issue is the following ,
when trying to set up counter 0 which is an 8 bit counter
to fastPwM
i use the following code
now before you read
understand i have tried the following
Change the interrupt to overflow , on compare match
also tried having no interrupt and just updating  the compare register everytime i update pwm
but the strange behavior is this..
it does what  i want it to do but...wrong
i want it to fade in and out out
instead it fades from 0 to 255 THREE TIMES
and then from 255 to 0  THREE TIMES...
where in the code am i telling it do it three times in between transitions ????
i want  one fade up and one fade down nice smooth transition..
unless i have a misunderstanding of how the timer works
int main(void)
       sei(); //global interrupts
DDRD |=(1<<PIND6); // set pin d6  OC0A to output
TCCR0A |= ((1<<WGM01) | (1<<WGM00)); // enable fast pwm
TCCR0A |= (1<<COM0A1); // clear on compare math , set at bottom
TIMSK0 |= (1<<OCIE0A);// compare match interrupt
OCR0A = ((pwm / 100) * 255.0 ) ;//value to compare to timer , aka pwm dudty cycle
TCCR0B |= (1<<CS00) ); // no prescale
while(1)
_delay_ms(10);
//just fade in and out , 8 bit mode
if (pwm >=255)
cycle = 0;
if(pwm <=1 )
cycle = 1;
if(cycle == 0 )
pwm --;
if (cycle == 1)
pwm++;
ISR (TIMER0_COMPA_vect)
OCR0A =  ((pwm / 100) * 255.0 ); // update  duty cycle again since it changes everytime around main loop
I could print the Arduino logo on a box of cereal and sell it as "Arduin-O's"
eddiea6987
interesting..i think its because of delay but then again it would happen every 10ms if it was indeed delay
its goes
0...255
0...255
0...255
255...0
255...0
255...0
not at all what it want
any ideas?
nickgammon
eddiea6987
sorry i didnt include the preprocessor code in my post
but i have pwm set as a global since its used all over the place
double  pwm = 0;
int cycle = 0;
JB_AU
How did you get past
Amateurs built the ark, Professionals built the Titanic
