Topic: LCD display with ILI9341 driver on Arduino (Read 282316 times) previous topic - next topic
micol
#165
Aug 11, 2014, 09:51 am Last Edit: Aug 11, 2014, 09:55 am by micol Reason: 1
Hello !
I cut the pin Vcc (input) of the card and sold a wire from the cable to Raw and now it works.
The 3.3 V data outputs are strong enough to drive the ILI9340.
*** Micol *** Les talibans du politiquement correct ont encore frappé. En 2017, la dernière victime est TEX.
Rastud
#166
Aug 12, 2014, 10:57 am Last Edit: Aug 12, 2014, 10:59 am by Rastud Reason: 1
Hi again! Im still working with the ili9341, finally im working with the adafruit libraries and trying to show a picture from the SD.
It looks like the code is ok because the monitor serial show me that info but the LCD is still white.
Quote
Initializing SD card...OK!
Loading image 'flower.bmp'
File size: 230454
Image Offset: 54
Header size: 40
Bit Depth: 24
Image size: 240x320
Loaded in 3846 ms
This is my code from the examples:
Code: [Select]
  This is our Bitmap drawing example for the Adafruit ILI9341 Breakout and Shield
  ----> http://www.adafruit.com/products/1651
  Check out the links above for our tutorials and wiring diagrams
  These displays use SPI to communicate, 4 or 5 pins are required to
  interface (RST is optional)
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  MIT license, all text above must be included in any redistribution
  Aditions by Carlos Silva - May 2014
#include <Adafruit_GFX.h>    // Core graphics library
#include "Adafruit_ILI9341.h" // Hardware-specific library
#include <SPI.h>
#include <SD.h>
// TFT display and SD card will share the hardware SPI interface.
// Hardware SPI pins are specific to the Arduino board type and
// cannot be remapped to alternate pins.  For Arduino Uno,
// Duemilanove, etc., pin 11 = MOSI, pin 12 = MISO, pin 13 = SCK.
// MEGA pin 51 = MOSI, pin 50 = MISO, pin 52 = SCK.
#define TFT_DC 9
#define TFT_CS 10
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
#define SD_CS 4
void setup(void) {
  tft.begin();
  tft.fillScreen(ILI9341_BLUE);
  Serial.print("Initializing SD card...");
  if (!SD.begin(SD_CS)) {
    Serial.println("failed!");
  Serial.println("OK!");
  bmpDraw("flower.bmp", 0, 0);
// This function opens a Windows Bitmap (BMP) file and
// displays it at the given coordinates.  It's sped up
// by reading many pixels worth of data at a time
// (rather than pixel by pixel).  Increasing the buffer
// size takes more of the Arduino's precious RAM but
// makes loading a little faster.  20 pixels seems a
// good balance.
#define BUFFPIXEL 20
void bmpDraw(char *filename, uint8_t x, uint16_t y) {
  File     bmpFile;
  int      bmpWidth, bmpHeight;   // W+H in pixels
  uint8_t  bmpDepth;              // Bit depth (currently must be 24)
  uint32_t bmpImageoffset;        // Start of image data in file
  uint32_t rowSize;               // Not always = bmpWidth; may have padding
  uint8_t  sdbuffer[3*BUFFPIXEL]; // pixel buffer (R+G+B per pixel)
  uint8_t  buffidx = sizeof(sdbuffer); // Current position in sdbuffer
  boolean  goodBmp = false;       // Set to true on valid header parse
  boolean  flip    = true;        // BMP is stored bottom-to-top
  int      w, h, row, col;
  uint8_t  r, g, b;
  uint32_t pos = 0, startTime = millis();
  if((x >= tft.width()) || (y >= tft.height())) return;
  Serial.print(F("Loading image '"));
  Serial.print(filename);
  Serial.println('\'');
  // Open requested file on SD card
  if ((bmpFile = SD.open(filename)) == NULL) {
    Serial.print(F("File not found"));
    return;
  // Parse BMP header
  if(read16(bmpFile) == 0x4D42) { // BMP signature
    Serial.print(F("File size: ")); Serial.println(read32(bmpFile));
    (void)read32(bmpFile); // Read & ignore creator bytes
    bmpImageoffset = read32(bmpFile); // Start of image data
    Serial.print(F("Image Offset: ")); Serial.println(bmpImageoffset, DEC);
    // Read DIB header
    Serial.print(F("Header size: ")); Serial.println(read32(bmpFile));
    bmpWidth  = read32(bmpFile);
    bmpHeight = read32(bmpFile);
    if(read16(bmpFile) == 1) { // # planes -- must be '1'
      bmpDepth = read16(bmpFile); // bits per pixel
      Serial.print(F("Bit Depth: ")); Serial.println(bmpDepth);
      if((bmpDepth == 24) && (read32(bmpFile) == 0)) { // 0 = uncompressed
        goodBmp = true; // Supported BMP format -- proceed!
        Serial.print(F("Image size: "));
        Serial.print(bmpWidth);
        Serial.print('x');
        Serial.println(bmpHeight);
        // BMP rows are padded (if needed) to 4-byte boundary
        rowSize = (bmpWidth * 3 + 3) & ~3;
        // If bmpHeight is negative, image is in top-down order.
        // This is not canon but has been observed in the wild.
        if(bmpHeight < 0) {
          bmpHeight = -bmpHeight;
          flip      = false;
        // Crop area to be loaded
        w = bmpWidth;
        h = bmpHeight;
        if((x+w-1) >= tft.width())  w = tft.width()  - x;
        if((y+h-1) >= tft.height()) h = tft.height() - y;
        // Set TFT address window to clipped image bounds
        tft.setAddrWindow(x, y, x+w-1, y+h-1);
        for (row=0; row<h; row++) { // For each scanline...
          // Seek to start of scan line.  It might seem labor-
          // intensive to be doing this on every line, but this
          // method covers a lot of gritty details like cropping
          // and scanline padding.  Also, the seek only takes
          // place if the file position actually needs to change
          // (avoids a lot of cluster math in SD library).
          if(flip) // Bitmap is stored bottom-to-top order (normal BMP)
            pos = bmpImageoffset + (bmpHeight - 1 - row) * rowSize;
          else     // Bitmap is stored top-to-bottom
            pos = bmpImageoffset + row * rowSize;
          if(bmpFile.position() != pos) { // Need seek?
            bmpFile.seek(pos);
            buffidx = sizeof(sdbuffer); // Force buffer reload
          for (col=0; col<w; col++) { // For each pixel...
            // Time to read more pixel data?
            if (buffidx >= sizeof(sdbuffer)) { // Indeed
              bmpFile.read(sdbuffer, sizeof(sdbuffer));
              buffidx = 0; // Set index to beginning
            // Convert pixel from BMP to TFT format, push to display
            b = sdbuffer[buffidx++];
            g = sdbuffer[buffidx++];
            r = sdbuffer[buffidx++];
            tft.pushColor(tft.color565(r,g,b));
          } // end pixel
        } // end scanline
        Serial.print(F("Loaded in "));
        Serial.print(millis() - startTime);
        Serial.println(" ms");
      } // end goodBmp
  bmpFile.close();
  if(!goodBmp) Serial.println(F("BMP format not recognized."));
// These read 16- and 32-bit types from the SD card file.
// BMP data is stored little-endian, Arduino is little-endian too.
// May need to reverse subscript order if porting elsewhere.
uint16_t read16(File &f) {
  uint16_t result;
  ((uint8_t *)&result)[0] = f.read(); // LSB
  ((uint8_t *)&result)[1] = f.read(); // MSB
  return result;
uint32_t read32(File &f) {
  uint32_t result;
  ((uint8_t *)&result)[2] = f.read();
  ((uint8_t *)&result)[3] = f.read(); // MSB
  return result;
My connection scheme (i know its not the correct pic but its my firts sketch with fritzing...)
http://s28.postimg.org/onn5mvj0d/ili9341_bb.jpg
Any suggestion?
micol
Hello Rastud,
You problem is exactly the same as mine. What you write is like my post N° 147 (page 10) and my photo (post #152 page 11)
Either with Adafruit library 9340 and woof.bmp or with Adafruit library 9341 and flower.bmp
I tried with MEGA, UNO, ProMini with the same results.
For other applications, I now use Ucglib library, but it dont allow showing a picture from SD.
casemod
What a mess  :smiley-eek:
Any suggestion?
At a first glance everything seems to be OK.
Not knowing the buffer specs I would try to reduce the SPI speed.
Place this on your setup and report
SPI_CLOCK_DIV64
Rastud
SPI_CLOCK_DIV64
Thanks for the advice but i still have the same results.
casemod
SPI_CLOCK_DIV64
The code you posted above was modified by me, so i am pretty sure it does work.
Ill give it a go and let you know. What's the buffer/level shifter you are using?
casemod
Just tested.
Since i didn't had a regular SD card at hand I used the card reader from other display, but other than that all standard.
Arduino mini powered from a lithium battery at 3.7V
[Prepare for the real mess  ]:D]
Just as a disclaimer i removed all the libraries and installed the ones from the zip file I uploaded earlier just to be sure. I am now using arduino 1.5.7
nid69ita
Very beautiful your desktop. There is a little chaos ... organized   :smiley-mr-green:
my name is IGOR, not AIGOR
casemod
Had to squeeze another breadboard between the keyboard and my actual project  ;)
Rastud
Hi casemod, thanks for your help but still i cant show the picture.
The buffer im using is the CD4050BE, i think that is ok, right?
On the other hand im using a 2Gb micro SD with a SD adapter in FAT32 format and i just have the picture with nothing else. Maybe there is any problem with that?
casemod
The SD seems to be working as per your last post,
Loaded in 3846 ms
So I am guessing the connections are OK. Grab some other library and try to get the LCD working on its own without the SD. Who knows, could be faulty.
micol
On yesterday, after about 4 months trying, I have got a bmp picture on my ILI9340.
I succeed with a ProMini 3.3 volts, witch avoid resistors and 4050. I don't know if it is the reason.
I use Adafruit_9340 library.  I don't succeed with Adafruit_9341 library.
I don't succed with ProMini 5 volts nor UNO nor MEGA.
Then, I modified the program so as to show several pictures alternantively. It works.
To save time, I made bmp pictures with 1 bit color (for instance black and white) but the program does not accept them and says : "BMP format not recognized". Is there any way to work with such pictures ?
casemod
I see no reason why they would not work on the mini if you power it from 3.3V skipping the resistors/buffer.
You have a nice 3.3V breadboard voltage regulator, just link that to the 5V pin on the Uno or VCC on the 16MHz mini.
You need to remove the 5V wire from the serial connector on the mini or remove the resettable fuse on the uno, as per photo (Ignore any other mods). Then you can select 3.3/5 at will. Ill make a tutorial on this at some point, just waiting for the crystals for another board I have in parts.
Check the attached photo - Just remove the resettable fuse
You still have to save them in 24 bit format.
I havent found a workarround for this, technically it could be much faster.
there is however a toturial on how to convert raw images to native RGB565 TFT format so that they are loaded much faster.
Check here:
http://arduinoexplained.blogspot.co.uk/2012/05/image-slideshow-with-arduino.html
micol
#178
Aug 15, 2014, 04:21 pm Last Edit: Aug 15, 2014, 04:30 pm by micol Reason: 1
Thank you for your quick answer.
You give me two ways of work. The hardware way will wait for another day and I explore the sotware way because the slideshow on the linked page is very attractive.
The link to a converter in the page is no more valid.
I downloaded another converter but it does not match. It is RGB565Converter_V0.3.
The result cannot be open by any software, even if I change the suffixe by .bmp.
The input picture size is 225 KO, the output size is 300 KO.
:smiley-roll:
casemod
:smiley-roll:
http://www.henningkarlsen.com/electronics/t_imageconverter565.php
Try this one and see if you get the same results.
BTW the modified file has its own extension, its not a bmp and trying to load it as such wont display a correct output.
The UTFT library supports this method. Try to install it and have a look at this sketch for reference (the panel is different)
https://github.com/stanleyhuangyc/ArduinoTFT/blob/master/SDImageViewer/SDImageViewer.ino
