Topic: servo library (Read 1 time) previous topic - next topic
wolos
has anyone used arduino with the Servo library from Wiring?  Servo.cpp v1.6 in the wiring cvs says it is arduino compatible, but I can't get it to work.
armadillo
i was wondering the same few weeks ago, i have some firmware code (from few friends that helped)  for the arduino that allows me to control 4 servos from pd (puredata) i have posted them somewhere in the forums, let me know if you dont find them so i post the url here below...
btw, can you describe the way you are using the wiring lib?
/a
wolos
armadillo,
It's been awhile since I tried to get the servo library to work - I think I followed this:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1147795595
Then I just googled "wriring cvs" and pulled the servo files from under the lib directory.
armadillo
eii! tx for answering, I will try that though i think i remember mellis saying that there was something that needed to be adapted from the wiring lib so they could work properly in the arduino...uhmm i forgot what it was regretfully..
anyways, i will give it a go.
/a
