Topic: How to use all pins on SAM3X8 ? (Read 943 times) previous topic - next topic
vmansmx5
Hi there guys im just in the process of designing a new PCB using the SAM3X8 witch will have a 3.2" touch display built in and lots of extras that the DUE dose not have.
I have been reading up on the Pin mapping of the chip there are a lot of pins on the chip that where not used on the DUE
That I would like to use But can I ? is the thing.
These the the pins not used ON THE due
PA5, PB28, PB29, PB30 ,PB31 PC11, PB0, PB1, PB2, PC10, PB3, PB4, PB5, PB6, PB7, PB8, PB9, PC0, PC20, PC27, PB22, PB23, PB24,
how can I use them as outputs do I need to change files to use them?
dongtiandegua
#1
Aug 13, 2013, 06:46 am Last Edit: Aug 13, 2013, 07:05 am by dongtiandegua Reason: 1
Hi, I have bought a board developed by others. It seems that we can use all pins on the board. My board is not arrived yet.
Recently they are raising fund:
http://www.indiegogo.com/projects/us-25-arduino-due-yes-taijiuino-due-makes-it-true-customize-your-own-arduino/x/4117557
You can see here. After my test, lets discuss more.
Graynomad
Quote
Yes, I think the PinDescription array in variant.cpp is the place to start.
_____
Rob
Rob Gray aka the GRAYnomad www.robgray.com
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
