Topic: Makezine Arduino theremin code (Read 4111 times) previous topic - next topic
rockman0730
This was a cool project to make, but the author didn't not have the code attached to his post, so I made my own code for his design
              Webpage-  http://makezine.com/projects/arduino-theremin/
Code: [Select]
#include <NewPing.h>
#include <Servo.h>
#define PING_PIN  2  // Arduino pin tied to both trigger and echo pins on the ultrasonic sensor.
#define MAX_DISTANCE 300 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(PING_PIN, PING_PIN, MAX_DISTANCE); // NewPing setup of pin and maximum distance.
Servo myservo;  // create servo object to control a servo
int val;    // variable to read the value from the analog pin
int prPin = 0; // Pin where the photo resistor is connected to
int prReading; // The analog reading from the photoresistor
int buzzerPin = 3; // Connect Buzzer to Pin 4
long buzzerFreq; // The frequency to buzz the buzzer
// You can experiment with these values:
long BUZZ_FREQ_MAX = 2500; // Maximum frequency for the buzzer
long PR_MAX = 1023; // Maximum value for the photoresistor
  Serial.begin(115200); // Open serial monitor at 115200 baud to see ping results.
pinMode(buzzerPin, OUTPUT); // set a pin for buzzer output
  myservo.attach(10);  // attaches the servo on pin 10 to the servo object
     prReading = analogRead(prPin); // Values 0-1023
    buzzerFreq = (prReading * BUZZ_FREQ_MAX) / PR_MAX;
    buzz(buzzerPin, buzzerFreq, 10);
  delay(30);                     // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
  unsigned int uS = sonar.ping(); // Send ping, get ping time in microseconds (uS).
  Serial.print("Ping: ");
  Serial.print(uS / US_ROUNDTRIP_CM); // Convert ping time to distance and print result (0 = outside set distance range, no ping echo)
  Serial.println("cm");
unsigned int cm = uS / US_ROUNDTRIP_CM;
   if(cm >= 45) {            // You can change values to suite
     val= 115;
   if(cm <= 39) {
     val= 170;
   if(cm <= 37) {
     val= 170;
   if(cm <= 33) {
     val= 170;
   if(cm <= 29) {
     val= 170;
   if(cm <= 27) {
     val= 170;
  if( cm <= 25) {
    val = 170;
   if(cm <= 24) {
     val= 165;
   if(cm <= 22) {
     val= 160;
   if(cm <= 20) {
     val= 155;
   if(cm <= 18) {
     val= 150;
   if(cm <= 16) {
     val= 145;
    if(cm <= 14) {
     val= 140;
   if(cm <= 12) {
     val= 135;
   if(cm <= 10) {
     val= 130;
   if(cm <= 8) {
     val= 125;
   if(cm <= 6) {
     val= 120;
   if(cm <= 4) {
     val= 115;
  myservo.write(val);                  // sets the servo position according to the scaled value
  delay(50);                         // waits for the servo to get there
void buzz(int targetPin, long frequency, long length) {
    long delayValue = 1000000/frequency/2;
    long numCycles = frequency * length/ 1000;
    for (long i=0; i < numCycles; i++){
        digitalWrite(targetPin,HIGH);
        delayMicroseconds(delayValue);
        digitalWrite(targetPin,LOW);
