Topic: Measuring the speed of a projectile (Read 13743 times) previous topic - next topic
successfulfailure
My school has a vacuum cannon and it fires small table tennis balls. We can only calculate the velocity theoretically because my school does not have any device that is capable of measuring a projectile traveling at around 350 to 400 m/s
I was thinking of using two tin foils and measuring the time interval of opening circuit. (Using a photo resistor would be too slow)
I did some research and I did find some useful resource: http://forum.arduino.cc/index.php/topic,114435.0.html
Please give me some advice on how I should tackle this problem. (Should I just use the method I found?)
CrossRoads
Photoresistor would be fine -  you have the same delay in detecting at two points, so they cancel out.
interval time = (T2+time_delay) - (T1+time_delay) = T2 +time_delay - T1 - time_delay = T2 - T1.
Also has the benefit of no tin foil impacting the time by slowing down the ball at all.
pito
Quote
That fast tennis balls - a joke :)
AWOL
Quote
Mach 1+ ping-pong balls?
Some serious over-estimation there, I think.
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
robtillaart
you can measure the soundpulse of the cannon firing and the soundpulse when it drops the floor or it hits the wall.
That too will give you two timestamps and a distance.
If you shoot right up in the air you can even determine the velocity of the ball leaving the canon as the ball makes (almost) a perfect parabola.
Gravity will decrease the velocity until it reaches zero
V = V0 - g x t
V = 0 when it is at the top, => V0 = g x t
g = 9.80665 (depends on where you live), and t is half the time between firing and the moment it hits earth again.
example:
so if t = 14.35 seconds  => 0.5 t = 7.17  => V0 = g x t = 9.81 x 7.17 = 70.34 m/s
The height the ball would come is 0.5 x g x t2 = 0.5 x 9.81 x 7.172 = 252.16 meter  (so don't test this indoors ;)
The above calculations do not include drag / friction.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
successfulfailure
#5
Aug 13, 2013, 01:48 pm Last Edit: Aug 13, 2013, 01:59 pm by successfulfailure Reason: 1
Quote
It is a 2 meters long vacuum cannon.
P = Atmospherics pressure = 101325 Pascal
r = 0.02 meters
A = (pi)(r)^2
F = PA
F = (101325)(3.14 X 0.04) = 12732.8750
W = Fd = (12732.8750)(2) =  25465.75
W = (1/2)(m)(V)^2
V = square root((2 X 25465.75)/0.04) = 1128
V = 1128 m/s
Considering energy loss, we are just assuming it to be around 350 m/s to 400 m/s
so around 780 mph to 895 mph
AWOL
successfulfailure
#7
Aug 13, 2013, 01:56 pm Last Edit: Aug 13, 2013, 02:19 pm by successfulfailure Reason: 1
I am just worried because I have never used a photoresistor for anything... and the projectile is moving very fast...
Also the photoresistor I have is a crap one (I believe) that just came with SparkFun Arduino starter kit...
Edit:
Based on simple calculation
Assuming it is traveling it at 350 m/s, a large projectile (cylinder shape with hemispheric nose and tail) which is around 6 cm
t = d/v = 0.06/350 = 0.0001714 seconds...
Arduino has 16 million clock cycle which is plenty to get readings but I think the photoresistor is just not that responsive...
AWOL
#8
Aug 13, 2013, 02:01 pm Last Edit: Aug 13, 2013, 02:17 pm by AWOL Reason: 1
Use a photodiode or phototransistor.
(your calculations assume a perfect vacuum on one side of the projectile)
Edit:
Sanity check.
0 - 340ms-1 implies a steady acceleration of v2 /2s = 3402 / 4 = 28 900ms-2 or about 2950g.
Can a ping-pong ball really sustain that?
pito
#9
Aug 13, 2013, 02:34 pm Last Edit: Aug 13, 2013, 02:58 pm by pito Reason: 1
www.phys.csuchico.edu/~lbuchholtz/Papers/VC_AJP.pdf
The above paper says it could be max 287m/s and 4700g (measured with ping-pong balls and photo gates 125-250m/s typically for 0.5 -2m cannon lengths).
successfulfailure
Do you think this Miniature Solar Cell - BPW34 will do the trick?
https://www.sparkfun.com/products/9541
Datasheet:
https://www.sparkfun.com/datasheets/Prototyping/Solar/bpw34.pdf
AWOL
Quote
No, I don't think it'll be fast enough
successfulfailure
Quote
Oh... I don't know what device to use now...
AWOL
I do believe I mentioned a photodiode or a phototransistor.
If you google "ballistic computer", you may even find circuits.
arduinoadrian
#14
Aug 18, 2013, 03:10 am Last Edit: Nov 14, 2013, 09:43 am by arduinoadrian Reason: 1
Quote
That's what you need, a photodiode or a phototransistor. I don't know why you want to use something different. They aren't that difficult to find.
Quote
I have the same impression. If the speed was to be that much, the ping pong ball will probably disintegrate inside the cannon.
