Topic: switch case statement problem (Read 3509 times) previous topic - next topic
bhaskarwankhede
Hi All,
I'm need help with the switch case statement for below code. I'm trying to create a menu screen for my Aquarium controller.
There are 2 issues with the code:
Issue 1:
when I run the below code it is running in sequence means I have to touch on the button 1 than 2 than 3 than 4 and so on. What I want is that I should be able to click on any button without any sequence.
Issue 2:
Also it is running only once. If I touch a button than I'm not able to click it again.
please guide me in right direction.
byte dispScreen=0;   // it is placed on the top before setup loop.
    if (myTouch.dataAvailable())  {
    myTouch.read();
    x=myTouch.getX();
    y=myTouch.getY();
    setx=myTouch.getX();
    sety=myTouch.getY();
    setx1=myTouch.getX();
    sety1=myTouch.getY();
    switch (dispScreen) {
    case 0:
if ((x>=mainBut[0]) && (x<=mainBut[2]) && (y>=mainBut[1]) && (y<=mainBut[3]))
clearScreen();
mainScreen();
waitForIt(mainBut[0], mainBut[1], mainBut[2], mainBut[3]);
myGLCD.print("MAIN", 22, 222, 1);
dispScreen = 1;
    break;
    case 1:
if ((x>=ledBut[0]) && (x<=ledBut[2]) && (y>=ledBut[1]) && (y<=ledBut[3]))
clearScreen();
LEDScreen();
waitForIt(ledBut[0], ledBut[1], ledBut[2], ledBut[3]);
myGLCD.print("LED", 75, 222, 1);
dispScreen = 2;
break;
    case 2:
if ((x>=tempBut[0]) && (x<=tempBut[2]) && (y>=tempBut[1]) && (y<=tempBut[3]))
clearScreen();
tempDisplay();
waitForIt(tempBut[0], tempBut[1], tempBut[2], tempBut[3]);
myGLCD.print("TEMP", 122, 222, 1);
dispScreen = 3;
break;
case 3:
if ((x>=pHBut[0]) && (x<=pHBut[2]) && (y>=pHBut[1]) && (y<=pHBut[3]))
clearScreen();
backgroundScreen();
waitForIt(165, 219, 205, 235);
myGLCD.print("pH", 100, 100, 1);
                dispScreen = 4;
break;
case 4:
if ((x>=settBut[0]) && (x<=settBut[2]) && (y>=settBut[1]) && (y<=settBut[3]))
clearScreen();
generalSettings();
waitForIt(settBut[0], settBut[1], settBut[2], settBut[3]);
myGLCD.print("SETTINGS", 230, 222, 1);
dispScreen = 5;
break;
case 5:
if (dispScreen = 5){
if ((setx>=dtSet[0]) && (setx<=dtSet[2]) && (sety>=dtSet[1]) && (sety<=dtSet[3]))
clearScreen();
dateTimeSettings();
dispScreen = 6;
if ((setx>=mlSet[0]) && (setx<=mlSet[2]) && (sety>=mlSet[1]) && (sety<=mlSet[3]))
clearScreen();
moonlight();
dispScreen = 7;
if ((setx>=ledSet[0]) && (setx<=ledSet[2]) && (sety>=ledSet[1]) && (sety<=ledSet[3]))
clearScreen();
backgroundScreen();
myGLCD.print("LED Settings", 100, 100, 1);
dispScreen = 8;
if ((setx>=tempSet[0]) && (setx<=tempSet[2]) && (sety>=tempSet[1]) && (sety<=tempSet[3]))
clearScreen();
backgroundScreen();
myGLCD.print("TEMP SETTING", 100, 100, 1);
dispScreen = 9;
if ((setx>=alaSet[0]) && (setx<=alaSet[2]) && (sety>=alaSet[1]) && (sety<=alaSet[3]))
clearScreen();
backgroundScreen();
myGLCD.print("ALARM SETTING", 100, 100, 1);
dispScreen = 10;
break;
case 6:
if (dispScreen = 6){
if ((setx1>=savBut[0]) && (setx1<=savBut[2]) && (sety1>=savBut[1]) && (sety1<=savBut[3]))
clearScreen();
generalSettings();
if ((setx1>=canBut[0]) && (setx1<=canBut[2]) && (sety1>=canBut[1]) && (sety1<=canBut[3]))
clearScreen();
generalSettings();
break;
case 8:
if (dispScreen = 7){
clearScreen();
generalSettings();
clearScreen();
generalSettings();
break;
  delay(100);
regards
BW
MAS3
This is not all of your code.
Post all of it to have all questions answered.
Have a look at "blink without delay".
Did you connect the grounds ?
Je kunt hier ook in het Nederlands terecht: http://arduino.cc/forum/index.php/board,77.0.html
bhaskarwankhede
Sorry for not posting full code.
#include <UTFT.h>
#include <UTouch.h>
extern uint8_t SmallFont[];
#define LARGE true
#define SMALL false
UTFT myGLCD(ITDB32S,38,39,40,41);
UTouch myTouch(6,5,4,3,2);
int i;
int x, y, setx, sety, setx1, sety1;
byte dispScreen=0;
unsigned long prevMillis05 = 0;
unsigned long prevMillis1 = 0;
unsigned long prevMillis5 = 0;
unsigned long prevMillis60 = 0;
unsigned long prevMillis600 = 0;
const int savBut[]= {40, 187, 130, 209};
const int canBut[]= {185, 187, 280, 209};
const int mainBut[] = {15, 219, 55, 235};
const int ledBut[] = {65, 219, 105, 235};
const int tempBut[] = {115, 219, 155, 235};
const int pHBut[] = {165, 219, 205, 235};
const int settBut[] = {215, 219, 300, 235};
const int dtSet[] = {25, 35, 295, 60};
const int mlSet[] = {25, 70, 295, 95};
const int ledSet[] = {25, 105, 295, 130};
const int tempSet[] = {25, 140, 295, 165};
const int alaSet[] = {25, 175, 295, 200};
 myGLCD.InitLCD();
 myGLCD.clrScr();
 myGLCD.setFont(SmallFont);
 myTouch.InitTouch();
mainScreen();
while (true)
     processMyTouch();
void backgroundScreen() {
//HEADER
myGLCD.setColor(255, 0, 0);
myGLCD.setBackColor(255, 0, 0);
myGLCD.fillRect(1, 1, 319, 239);
myGLCD.setColor(255, 255, 255);
myGLCD.print("DATE", 5, 5, 1);
myGLCD.print("CONTROLLER V1", CENTER, 5, 1);
myGLCD.print("TIME", RIGHT, 5, 1);
//BODY
myGLCD.setColor(153, 50, 204);
myGLCD.setBackColor(153, 50, 204);
myGLCD.fillRect(1, 25, 319, 221);
//FOOTER
myGLCD.setColor(0, 0, 255);
myGLCD.setBackColor(0, 0, 255);
myGLCD.fillRoundRect (15, 219, 55, 235);
myGLCD.fillRoundRect (65, 219, 105, 235);
myGLCD.fillRoundRect (115, 219, 155, 235);
myGLCD.fillRoundRect (165, 219, 205, 235);
myGLCD.fillRoundRect (215, 219, 300, 235);
myGLCD.print("pH", 178, 222, 1);
myGLCD.fillRect(15, 219, 300, 221);
void hlightUpButton(int x, int y)
 myGLCD.setColor(0, 0, 125);
 for (int i=0; i<15; i++)
    myGLCD.drawLine(x+4+(i/1.5), y+17-i, x+25-(i/1.5), y+17-i);
 while (myTouch.dataAvailable()) {
   myTouch.read();
 myGLCD.setColor(0, 255, 255);
void hlightDownButton(int x, int y)
    myGLCD.drawLine(x+4+(i/1.5), y+7+i, x+25-(i/1.5), y+7+i);
   myTouch.read();
void MyDelay(int x, int y)
 myGLCD.print("0", x, y);
 long  now = millis();
 long  end = now + 500;
 while(millis() < end)
   //myGLCD.printNumI(i, x, y);
void waitForIt(int x2, int y2, int x3, int y3)
 myGLCD.drawRoundRect (x2, y2, x3, y3);
   myTouch.read();
 myGLCD.fillRoundRect (x2, y2, x3, y3);
void printButton(char* text, int x1, int y1, int x2, int y2, byte cr, byte cg, byte cb, byte br, byte bg, byte bb)
 int stl = strlen(text);
 int fx, fy;
 fx = x1+(((x2 - x1)-(stl*8))/2);
 fy = y1+(((y2 - y1-1)-8)/2);
 myGLCD.setColor(cr, cg, cb);
 myGLCD.setBackColor(cr, cg, cb);
 myGLCD.fillRoundRect(x1, y1, x2, y2);
 myGLCD.setColor(br, bg, bb);
 myGLCD.print(text, fx, fy);
void generalSettings(){
myGLCD.clrScr();
backgroundScreen();
myGLCD.fillRoundRect (25, 35, 295, 60);
myGLCD.fillRoundRect (25, 70, 295, 95);
myGLCD.fillRoundRect (25, 105, 295, 130);
myGLCD.fillRoundRect (25, 140, 295, 165);
myGLCD.fillRoundRect (25, 175, 295, 200);
myGLCD.print("DATE & TIME SETTINGS", CENTER, 40, 1);
myGLCD.print("MOONLIGHT SETTINGS", CENTER, 75, 1);
myGLCD.print("LED SETTINGS", CENTER, 110, 1);
myGLCD.print("TEMPERATURE SETTINGS", CENTER, 145, 1);
myGLCD.print("ALARM SETTINGS", CENTER, 180, 1);
void mainScreen(){
myGLCD.clrScr();
backgroundScreen();
myGLCD.print("MAIN SCREEN", 100, 100, 1);
void dateTimeSettings(){
myGLCD.clrScr();
backgroundScreen();
myGLCD.print("DATE & TIME SETTINGS", 100, 100, 1);
printButton("SAVE", 40, 187, 130, 209, 0, 0, 255, 255, 255, 255);
printButton("cancel", 185, 187, 280, 209, 0, 0, 255, 255, 255, 255);
void LEDScreen(){
myGLCD.clrScr();
backgroundScreen();
myGLCD.print("LED SCREEN", 100, 100, 1);
void moonlight(){
myGLCD.clrScr();
backgroundScreen();
myGLCD.print("MOON LIGHT SETTINGS", 100, 100, 1);
void tempDisplay(){
       myGLCD.clrScr();
       backgroundScreen();
       myGLCD.print("TEMP DISPLAY", 100, 100, 1);
void clearScreen()
myGLCD.setColor(0, 0, 0);
myGLCD.fillRect(1, 1, 318, 239);
void processMyTouch()
   myTouch.read();
   x=myTouch.getX();
   y=myTouch.getY();
   prevMillis600 = millis();
   case 0:
clearScreen();
mainScreen();
           dispScreen = 1;
   break;
   case 1:
           clearScreen();
LEDScreen();
           dispScreen = 2;
break;
   case 2:
           clearScreen();
           tempDisplay();
           dispScreen = 3;
break;
case 3:
clearScreen();
backgroundScreen();
           dispScreen = 4;
break;
case 4:
   clearScreen();
           generalSettings();
           dispScreen = 5;
break;
case 5:
           clearScreen();
           dateTimeSettings();
           dispScreen = 6;
clearScreen();
           moonlight();
           dispScreen = 7;
           clearScreen();
           backgroundScreen();
           dispScreen = 8;
           clearScreen();
           backgroundScreen();
           dispScreen = 9;
            clearScreen();
            backgroundScreen();
            dispScreen = 10;
break;
case 6:
             clearScreen();
             generalSettings();
           clearScreen();
           generalSettings();
break;
case 7:
           clearScreen();
           generalSettings();
            clearScreen();
            generalSettings();
break;
 //delay(100);
Henry_Best
mainScreen();
while (true)
while WHAT is true??? If you don't specify it, the while loop will continue for ever and ever and ever and ever.....
   case 0:
   break;
   case 1:
   break;
   case 2:
   break;
   case 3:
   break;
   case 4:
   break;
   case 5:
Ignoring the syntax error, how could dispScreen be anything other than 5 here?
case 6:
Ignoring the syntax error, how could dispScreen be anything other than 6 here?
case 7:
Ignoring the syntax error, how could dispScreen be anything other than 7 here?
Delta_G
It looks like you're setting dispScreen to a new number at the end of each of those first few cases.  I can't find where you're setting it to anything that is coming from the screen.  So I wouldn't think it would matter which number you select, it is going to run through 0 and in case zero it gets set to 1, then the next time a reading is available it will run case 1 where it gets set to 2 and then case 2 and so on.
|| | ||| | || | ||  ~Woodstock
JohnHoward
if REASSIGN: if (dispScreen = 6)
if COMPARE: if(dispScreen == 6)
Which did you want?  Your code reassigns the value of dispScreen at each if statement.
Henry_Best
Hence my "Ignoring the syntax error". But those if statements are redundant. Switch case will only take the program to, say, case 6 if dispScreen is already == 6. There's no need to check dispScreen's value again.
bhaskarwankhede
I think I know where the problem is. I will try to modify it.
I'm very new to coding & this is my first time coding. Most of the codes which I have written are modified codes available on internet.
Any pointer what need to be modify will really help.
JohnHoward
Oh, ok.   I was ignoring the } syntax mismatch.  But you have
ending } right above the delay(100), so it encloses the cases 6 through 9.
Is that a syntax error to ignore or is that the problem?
Henry_Best
I hadn't spotted that one. We appear to be talking at crossed purposes.
But you have
The mismatch is another problem.
JohnHoward
I guess it's time to sprinkle Serial.Print() statements throughout the case statement, so you can see where it's going when you punch a button.
bhaskarwankhede
working on it.
bhaskarwankhede
I'm now able to use the menu screen as I want. Below is the modified code. Please let me know if you still see any issue with the code.
      case 0:
backgroundScreen();
dispScreen=1;
Serial.println(dispScreen);
      break;
      case 1:
clearScreen();
mainScreen();
dispScreen = 1;
clearScreen();
LEDScreen();
dispScreen = 1;
clearScreen();
tempDisplay();
dispScreen = 1;
clearScreen();
backgroundScreen();
dispScreen = 1;
clearScreen();
generalSettings();
dispScreen = 2;
break;
case 2:
clearScreen();
dateTimeSettings();
dispScreen = 3;
clearScreen();
moonlightSettings();
dispScreen = 3;
clearScreen();
backgroundScreen();
ledSettings();
dispScreen = 3;
clearScreen();
backgroundScreen();
tempSettings();
dispScreen = 3;
clearScreen();
backgroundScreen();
pHSettings();
dispScreen = 3;
if ((setx>=bacButt[0]) && (setx<=bacButt[2]) && (sety>=bacButt[1]) && (sety<=bacButt[3]))
clearScreen();
backgroundScreen();
dispScreen = 1;
break;
case 3:
clearScreen();
generalSettings();
dispScreen = 2;
clearScreen();
generalSettings();
dispScreen = 2;
break;
