Topic: New tutorial - Arduino and the NXP PCF8563 real time clock IC (Read 16060 times) previous topic - next topic
tronixstuff
Aug 13, 2013, 04:23 am Last Edit: Aug 20, 2013, 03:17 pm by tronixstuff Reason: 1
A few people asked me for a tutorial on how to use the NXP PCF8563 real time clock IC. So here you go:
http://tronixstuff.com/2013/08/13/tutorial-arduino-and-pcf8563-real-time-clock-ic/
which explains the time, date, oscillator outputs, alarm function and error-checking.
A couple of Arduino tutorials at http://tronixstuff.com/tutorials - My Arduino book - http://nostarch.com/arduino. Please don't ask for help via direct message - use the forum!
mark7w
#1
Aug 24, 2013, 07:21 pm Last Edit: Aug 24, 2013, 07:31 pm by mark7w Reason: 1
I like this, karma awarded. :)
oh, does your e-book have color photos?
tronixstuff
Thanks. The print and electronic versions are in grey-scale.
canibalimao
#3
Sep 17, 2013, 06:06 pm Last Edit: Sep 17, 2013, 06:16 pm by canibalimao Reason: 1
Sorry for bring this from the grave but I'm having some problems with the RTC.
Well, I don't know if this is really a RTC clock problem or if it's an arduino problem. I'm using an Arduino Leonardo (maybe the fault is here) with a PCF8563 and a 32.768 kHZ crystal.
I'd tried to use the arduino "official" library for the PCF8563 and now I'm trying with your code and the results are the same:
Code: [Select]
45/25/20165 - 45:85:85
Is there anything I need to change in some library to make it work with Leonardo?
I have 10 RTC chips (all the same model) and all of them show the same result...
Hope you can help a noobie here  :smiley-red:
tronixstuff
Code: [Select]
Leonardo - OK, the pins are different. I2C SDA is 2 and SCL is 3. Double-check your wiring and then try my example 54.1 sketch again.
Out of curiosity, where did you get the PCF8563s from?
canibalimao
Code: [Select]
Thank you very much. I just need to change the wiring, or need to change other thing else on the code?
On eBay, from a chinese guy  :smiley-mr-green:
tronixstuff
Code: [Select]
Code should be fine. Are you in Australia by any chance?
canibalimao
#7
Sep 18, 2013, 01:35 pm Last Edit: Sep 18, 2013, 05:27 pm by canibalimao Reason: 1
Code: [Select]
Thank you very much. Latter on I'll try that and give here some feedback.
No, I'm from Portugal.
And by the way, what a great website you have with all the tutorials   :D
PS: I saw now that the leonardo board has an SCL and an SCA separate pin header. Should I use this instead the A3 and A2?
EDIT: It's working finally! :D
Thank you very much tronix! It's working using the SCL and SDA dedicated ports on the board (the 2 one on the left of Digital side).
Now let's play :D
tronixstuff
