Topic: Z-Wave Controllers Compatible with Arduino (Read 45566 times) previous topic - next topic
kenstcyr
Hi everyone -
I'm leaning towards using Z-Wave with Arduino driving the controller.  I've looked at a few different controllers, but the interfaces into them aren't that clean cut.  Right now, I'm thinking the best path is to get something with a serial interface (such as the HomeSeer Z-Troller - http://store.homeseer.com/store/HomeSeer-Z-Troller-Z-Wave-Controller-P214C66.aspx).
Has anyone else done something similar?  If so, what hardware did you use and how did you interface to it from the Arduino?
Thanks!
//Ken
jonspeedr
consider using leviton VRCOP-1LW and VRUSB-1US
vrcop is the 232 interface
vrusb is for setting up the zwave network
Don't know a lot about them but may be worth researching.
wycc
Check this one.
http://www.ebay.com/sch/i.html?_trksid=p2050601.m570.l1313.TR0.TRC0.Xarduino+zwave&_nkw=arduino+zwave&_sacat=0&_from=R40
It's a arduino compatible board with zwave support. It can be used for both slave and controller.
Leonzio
Don't be fooled by these "Z-Wave compatible" RF modules. They claim compatibility only because they work on same or similar RF frequency ranges but normally you have to implement the full Z-Wave protocol stack, which is not an easy game...
Infact if you look at the end of the specs you'll see the vendor's discailmer:
Note: this module works on Z-wave frequency, but not on Z-wave protocol.
In addition to frequency you have to take care of the type of modulation supported by the RF module. Z-Wave works with FSK modulation with Manchester or NRZ binary encoding depending on the data speed (9600 or 40000 baud).
In my opinion the ACT or HomePro ZCS101 Z-Wave RS232 Interface (rated at about $50) should be ok and cheaper than the Leviton.
Andrea
wycc
Check this one.
It is an arduino compatible board with Z-Wave module. It has some sketches for binary sensor sensor and temperature sensors. In the follwoing site
https://sites.google.com/site/arduinozwave/installation/arduino/implement-binary-sensor-in-the-hc-20
PoltoS
The thread is old, but now there is what you need: https://z-uno.z-wave.me
Z-Uno is an Arduino IDE compatible board. It have Z-Wave on board and can be programmed like an Arduino in the same language.
cmgreenman
Only problem is they don't offer a North America 900Mhz version yet.  US and Canada will have to "Stay Tuned" according to their site.
PoltoS
Z-Uno is now available in US too. Just ordered few pieces on https://z-uno.us
Ben_Z
There is also an z-wave compatible arduino board called ZIY but it's quite unpopular...
