Topic: array-BUG (Read 1 time) previous topic - next topic
Joegi
Aug 15, 2013, 06:16 pm Last Edit: Aug 15, 2013, 06:19 pm by Joegi Reason: 1
...the following code crashes the Atmega and leads to strange behaviour of it!
ONLY RUN IT WITH NOTHING CONNECTED TO THE ARDUINO!
Code: [Select]
byte a[6000] = {1};
 pinMode(13, OUTPUT);
 a[5] = 10;
 digitalWrite(13, HIGH);
 digitalWrite(13, LOW);
The reason is the length of the array. If you shorten it, everything works fine!
I only tested the code on two UNOs!
Joegi
#1
Aug 15, 2013, 06:28 pm Last Edit: Aug 15, 2013, 06:30 pm by Joegi Reason: 1
...oh stupid me, I forgot that the Atmega 328P only has two kbytes of static RAM, but the program shouldn't upload!
ajk_
Well, other than the fact that the ancient G++ version has issues with initialized arrays to begin with... I've run into this bug myself, and I'm forced to init global arrays manually every time because of old tools and work around all sorts of other odd bugs.
See link here http://forum.arduino.cc/index.php?topic=184131.0 and get on to git-hub, and complain with a bug report about outdated tools.
Coding Badly
Please post a complete sketch that illustrates the problem.
ajk_
Not a complete sketch, and not G++, but GCC (which iirc uses GCC anyway)
http://forum.arduino.cc/index.php?topic=184131.msg1372344#msg1372344
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
