Topic: serial read garbage problem (Read 1 time) previous topic - next topic
Abubakar022
i am a newbie and i want to send a simple integer to arduino via serial communication, i get the value but there is also garbage valuse i don't understand to reslove it... a little help will be appreciated.
  while (Serial.available() == 0);
  int val = Serial.read() - '0';
  Serial.flush();
  Serial.println(val);
majenko
You have newline sending enabled.
When you send the number '7' for instance, you are actually sending the string "7\n", which is characters 55 and 10.  '0' is character 48, so 55 - 48 yeilds 7.  However, 10 - 48 yields -38.
nickgammon
http://www.gammon.com.au/serial
Abubakar022
thanks it make sense can you tell me how to resolve the new line?
majenko
By selecting the option not to send a newline in the serial monitor.  The drop-down box that says "Newline" at the moment.  Change it.
nickgammon
I hope you aren't going to want to send more than "9" to the serial port, or you may have to rethink your approach. And you may have to read this:
majenko
I'm sure that URL looks somewhat familiar... Haven't I seen it somewhere before?
