Topic: Can't Use Pin 8 On the 74hc595 Shift Register (Read 1 time) previous topic - next topic
jreeve17
Hi, I just got my first shift registers and am learning how to use them. I found this site- http://bildr.org/2011/08/74hc595-breakout-arduino/ There was a great library there that made it easier to use this shift register and I am using it now. The only problem is that I can't individually control pin 8. The pin works fine and responds normally when using
Code: [Select]
shifter.setAll(HIGH);
shifter.write();
but when I use
Code: [Select]
shifter.setPin(8, HIGH);
shifter.write();
the pin does nothing.
Can anyone help me with this problem and tell me what I am doing wrong? Any help would be appreciated.
This is a rather lengthy sketch that I wrote to test out this problem-
Code: [Select]
#include <Shifter.h>
#define SER_Pin 4 //SER_IN
#define RCLK_Pin 5 //L_CLOCK
#define SRCLK_Pin 6 //CLOCK
#define NUM_REGISTERS 1 //how many registers are in the chain
//initaize shifter using the Shifter library
Shifter shifter(SER_Pin, RCLK_Pin, SRCLK_Pin, NUM_REGISTERS);
void setup(){
shifter.clear();
shifter.write();
delay(100);
void loop(){
shifter.setPin(1, HIGH);
shifter.write();
shifter.clear();
shifter.write();
delay(100);
shifter.setPin(2, HIGH);
shifter.write();
shifter.clear();
shifter.write();
delay(100);
shifter.setPin(3, HIGH);
shifter.write();
shifter.clear();
shifter.write();
delay(100);
shifter.setPin(4, HIGH);
shifter.write();
shifter.clear();
shifter.write();
delay(100);
shifter.setPin(5, HIGH);
shifter.write();
shifter.clear();
shifter.write();
delay(100);
shifter.setPin(6, HIGH);
shifter.write();
shifter.clear();
shifter.write();
delay(100);
shifter.setPin(7, HIGH);
shifter.write();
shifter.clear();
shifter.write();
delay(100);
shifter.write();
shifter.clear();
shifter.write();
delay(100);
shifter.write();
shifter.clear();
shifter.write();
delay(100);
nickgammon
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
jreeve17
Are you sure it isn't 7? (Pins 0 to 7)
Yes, this shift register has 8 outputs
nickgammon
jreeve17
YES! Thank you that worked. I was using pins 1-8 not 0-7. Thank you so much.
