Topic: Arduino Hangs when I connect it to Ethernet Shield + 4in1 Relay Board. (Read 6739 times) previous topic - next topic
Akshaysarraf
Aug 17, 2013, 11:41 am Last Edit: Aug 28, 2013, 07:04 am by CrossRoads Reason: 1
Guys, I am New to Arduino and Stuff. I dont know much about it Technical Stuff. I googled many stuff and find out some ways to control my lights using Arduino + Ethernet Shield + Relay Board.
So i got them all. Now My problem is when I connect it to my Home appliances (like Lights and all) it works for 2 to 3 Control and then hangs.
I am using a simple Arduino with Atmega328 Chip
My replay Board is this one :- http://positronindia.in/PT0003.aspx
My Ethernet shield is -  http://i01.i.aliimg.com/wsphoto/v0/720521831/Hot-ENC28J60-Network-Module-With-SPI-interface-25MHz-Ethernet-Module-for-AVR-51-LPC-Development-Board.jpg
The program I'm using i copied it from internet. It was originally to control LED's. But I am read somewhere that instead of LED's I could connect it to Relay's Digital pins and could control Relays
Code: [Select]
#include <EtherCard.h>
#define LED1PIN  4
#define LED2PIN  5
#define LED3PIN  6
#define LED4PIN  7
PROGMEM prog_char led_off[]= {
            0x89, 0x50, 0x4E, 0x47, 0x0D, 0x0A, 0x1A, 0x0A, 0x00, 0x00, 0x00, 0x0D, 0x49, 0x48, 0x44, 0x52, 0x00, 0x00, 0x00, 0x0E,
            0x00, 0x00, 0x00, 0x0E, 0x08, 0x04, 0x00, 0x00, 0x00, 0xB5, 0x41, 0xE5, 0x5A, 0x00, 0x00, 0x00, 0x01, 0x73, 0x52, 0x47,
            0x42, 0x00, 0xAE, 0xCE, 0x1C, 0xE9, 0x00, 0x00, 0x00, 0x02, 0x62, 0x4B, 0x47, 0x44, 0x00, 0xFF, 0x87, 0x8F, 0xCC, 0xBF,
            0x00, 0x00, 0x00, 0x09, 0x70, 0x48, 0x59, 0x73, 0x00, 0x00, 0x0B, 0x12, 0x00, 0x00, 0x0B, 0x12, 0x01, 0xD2, 0xDD, 0x7E,
            0xFC, 0x00, 0x00, 0x00, 0x07, 0x74, 0x49, 0x4D, 0x45, 0x07, 0xDC, 0x01, 0x1D, 0x14, 0x21, 0x10, 0xBC, 0x3C, 0xDE, 0x2D,
            0x00, 0x00, 0x00, 0xD2, 0x49, 0x44, 0x41, 0x54, 0x18, 0xD3, 0x75, 0xD0, 0xB1, 0x4A, 0x03, 0x51, 0x10, 0x05, 0xD0, 0xB3,
            0x21, 0x1F, 0x10, 0x04, 0x3B, 0x53, 0x89, 0x5A, 0x09, 0x9B, 0x58, 0xD9, 0x25, 0x5F, 0x60, 0x63, 0x9F, 0x87, 0x5F, 0xE0,
            0x27, 0x6D, 0x7A, 0x5B, 0xC1, 0x6E, 0xF3, 0x01, 0x92, 0x2C, 0x36, 0x56, 0x62, 0x61, 0x23, 0xA4, 0xB1, 0x12, 0xF2, 0x64,
            0xDF, 0x5A, 0xBC, 0x20, 0x5B, 0x98, 0x3B, 0xC5, 0xC0, 0xBD, 0x73, 0xEF, 0x30, 0x53, 0x74, 0x0E, 0x63, 0x48, 0x01, 0xC2,
            0xBD, 0x1B, 0x33, 0xAC, 0x2C, 0xAB, 0x0A, 0x3A, 0x45, 0xA7, 0x10, 0x46, 0xEA, 0x69, 0x39, 0x71, 0x21, 0xD9, 0x78, 0xF5,
            0xD2, 0x98, 0x57, 0x5F, 0x9D, 0x21, 0xA8, 0xEF, 0xCA, 0x53, 0xDF, 0xB6, 0xA2, 0x23, 0xD7, 0xC6, 0xE5, 0x63, 0x6D, 0xC2,
            0x80, 0x10, 0xA6, 0xE5, 0xB9, 0x9D, 0xA4, 0xD5, 0x4A, 0xA2, 0x91, 0xB3, 0x32, 0x04, 0x06, 0x58, 0x5C, 0x89, 0x92, 0x56,
            0xFA, 0xAB, 0x63, 0x16, 0x59, 0x9C, 0x5D, 0xF6, 0xA4, 0xDC, 0x4F, 0x98, 0xC9, 0x3B, 0x33, 0xD5, 0x77, 0x46, 0x64, 0xE7,
            0xAA, 0xE9, 0xD1, 0x79, 0x68, 0xCB, 0x2A, 0x8B, 0xCB, 0x0D, 0xBD, 0xC8, 0x24, 0xF9, 0x60, 0x69, 0x7F, 0xE7, 0xE6, 0xB6,
            0x1C, 0x8B, 0xA2, 0x1F, 0xD1, 0xCE, 0xBB, 0x75, 0x53, 0x4D, 0x3A, 0x03, 0x30, 0x7F, 0x68, 0x9E, 0xBC, 0x29, 0xB4, 0x3E,
            0x3D, 0x5B, 0x37, 0xE6, 0xEC, 0x9D, 0x10, 0x82, 0xC5, 0x3F, 0xEF, 0x3B, 0x8C, 0x5F, 0xC2, 0x84, 0x6A, 0x7B, 0xFB, 0x42,
            0x44, 0xCC, 0x00, 0x00, 0x00, 0x00, 0x49, 0x45, 0x4E, 0x44, 0xAE, 0x42, 0x60, 0x82
PROGMEM prog_char led_on[]= {
            0x00, 0x00, 0x00, 0x0E, 0x04, 0x03, 0x00, 0x00, 0x00, 0xED, 0x66, 0x30, 0xE2, 0x00, 0x00, 0x00, 0x01, 0x73, 0x52, 0x47,
            0x42, 0x00, 0xAE, 0xCE, 0x1C, 0xE9, 0x00, 0x00, 0x00, 0x27, 0x50, 0x4C, 0x54, 0x45, 0x00, 0x00, 0x00, 0xFF, 0xCC, 0x00,
            0xCC, 0x66, 0x00, 0xFF, 0xFF, 0x33, 0xFF, 0x99, 0x00, 0xFF, 0xCC, 0x33, 0xCC, 0x99, 0x66, 0xFF, 0xFF, 0x99, 0xCC, 0x99,
            0x33, 0xCC, 0x99, 0x00, 0xFF, 0xCC, 0x66, 0x99, 0x66, 0x00, 0xFF, 0xCC, 0x99, 0x4A, 0x4E, 0xC9, 0x79, 0x00, 0x00, 0x00,
            0x01, 0x74, 0x52, 0x4E, 0x53, 0x00, 0x40, 0xE6, 0xD8, 0x66, 0x00, 0x00, 0x00, 0x01, 0x62, 0x4B, 0x47, 0x44, 0x00, 0x88,
            0x05, 0x1D, 0x48, 0x00, 0x00, 0x00, 0x09, 0x70, 0x48, 0x59, 0x73, 0x00, 0x00, 0x0B, 0x12, 0x00, 0x00, 0x0B, 0x12, 0x01,
            0xD2, 0xDD, 0x7E, 0xFC, 0x00, 0x00, 0x00, 0x07, 0x74, 0x49, 0x4D, 0x45, 0x07, 0xDC, 0x01, 0x1D, 0x14, 0x23, 0x1C, 0x87,
            0xBC, 0xF0, 0x84, 0x00, 0x00, 0x00, 0x48, 0x49, 0x44, 0x41, 0x54, 0x08, 0xD7, 0x63, 0x60, 0x80, 0x03, 0x26, 0x25, 0x05,
            0x30, 0x95, 0x55, 0x3E, 0x0D, 0xC4, 0xD0, 0x31, 0x16, 0x14, 0x6C, 0x02, 0xD2, 0xC9, 0x86, 0x82, 0x82, 0xD2, 0x40, 0xE1,
            0xC5, 0x40, 0x3A, 0x44, 0x81, 0x81, 0xA9, 0x18, 0x46, 0x0B, 0x0A, 0x8A, 0xBA, 0x00, 0xE9, 0x60, 0x08, 0xCD, 0x90, 0x0C,
            0xA4, 0x9D, 0x80, 0xEA, 0x35, 0x80, 0xD2, 0x20, 0x9A, 0xA9, 0x53, 0xD0, 0x49, 0x01, 0xC9, 0x5C, 0x08, 0x00, 0x00, 0x9A,
            0x56, 0x0B, 0x58, 0x9D, 0x6A, 0x76, 0x99, 0x00, 0x00, 0x00, 0x00, 0x49, 0x45, 0x4E, 0x44, 0xAE, 0x42, 0x60, 0x82
static byte mymac[] = {0x54, 0x55, 0x58, 0x10, 0x00, 0x24};
static byte myip[] = {192,168,1,15};
byte Ethernet::buffer[700];
boolean led1Status;
boolean led2Status;
boolean led3Status;
boolean led4Status;
void setup () {
 Serial.begin(57600);
 Serial.println("WebLeds Demo");
 if (!ether.begin(sizeof Ethernet::buffer, mymac, 10))
   Serial.println( "Failed to access Ethernet controller");
  Serial.println("Ethernet controller initialized");
 if (!ether.staticSetup(myip))
   Serial.println("Failed to set IP address");
 pinMode(LED1PIN, OUTPUT);
 pinMode(LED2PIN, OUTPUT);
 pinMode(LED3PIN, OUTPUT);
 pinMode(LED4PIN, OUTPUT);
 digitalWrite(LED1PIN, LOW);
 digitalWrite(LED2PIN, LOW);
 digitalWrite(LED3PIN, LOW);
 digitalWrite(LED4PIN, LOW);
 led1Status = false;
 led2Status = false;
 led3Status = false;
 led4Status = false;
 word len = ether.packetReceive();
 word pos = ether.packetLoop(len);
 if(pos) {
   if(strstr((char *)Ethernet::buffer + pos, "GET /led_off.png") != 0)
     send_png_image(led_off, sizeof(led_off));
   else if(strstr((char *)Ethernet::buffer + pos, "GET /led_on.png") != 0)
     send_png_image(led_on, sizeof(led_on));
   else {
     if(strstr((char *)Ethernet::buffer + pos, "GET /?LED1") != 0) {
       led1Status = !led1Status;
       digitalWrite(LED1PIN, led1Status);
     if(strstr((char *)Ethernet::buffer + pos, "GET /?LED2") != 0) {
       led2Status = !led2Status;
       digitalWrite(LED2PIN, led2Status);
     if(strstr((char *)Ethernet::buffer + pos, "GET /?LED3") != 0) {
       led3Status = !led3Status;
       digitalWrite(LED3PIN, led3Status);
     if(strstr((char *)Ethernet::buffer + pos, "GET /?LED4") != 0) {
       led4Status = !led4Status;
       digitalWrite(LED4PIN, led4Status);
     BufferFiller bfill = ether.tcpOffset();
     bfill.emit_p(PSTR("HTTP/1.0 200 OK\r\n"
       "Content-Type: text/html\r\nPragma: no-cache\r\n\r\n"
       "<html><head><title>WebLeds</title></head><body>"
       "Welcome to Sarraf's Home Automation System!<br>"));
     if(led1Status) bfill.emit_p(PSTR("Tubelight => <a href=\"/?LED1\"> <img src=\"led_on.png\"></a><br>"));
     else bfill.emit_p(PSTR("Tubelight => <a href=\"/?LED1\"> <img src=\"led_off.png\"></a><br>"));
     if(led2Status) bfill.emit_p(PSTR("CFL => <a href=\"/?LED2\"> <img src=\"led_on.png\"></a><br>"));
     else bfill.emit_p(PSTR("CFL => <a href=\"/?LED2\"> <img src=\"led_off.png\"></a><br>"));
     if(led3Status) bfill.emit_p(PSTR("Extension Socket => <a href=\"/?LED3\"> <img src=\"led_on.png\"><br></a>"));
     else bfill.emit_p(PSTR("Extension Socket => <a href=\"/?LED3\"><img src=\"led_off.png\"><br></a>"));
     if(led4Status) bfill.emit_p(PSTR("Porche's Light => <a href=\"/?LED4\"> <img src=\"led_on.png\"></a><br>"));
     else bfill.emit_p(PSTR("Porche's Light => <a href=\"/?LED4\"><img src=\"led_off.png\"></a><br>"));
     bfill.emit_p(PSTR("</body></html>"));
     ether.httpServerReply(bfill.position());
void send_png_image(PGM_P png_image, unsigned int image_size) {
   "Content-Type: image/png\r\n\r\n"));
 bfill.emit_raw_p(png_image, image_size);
Please Help Guys. I am really Strucked here!
runaway_pancake
Ethernet boards strain the Arduino 5V supply, leaving little capacity for anything else.
Does a sketch running just the relay board (no ethernet board in place) work right?
If things are good with just the relay board, and then they get dodgy with the Ethernet board in place, then you have a diagnosis.
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
jack wp
That relay board uses 12V supply.
Where is the relay board power coming from?
Akshaysarraf
Arduino is powering just the... Ethernet Shield. I am providing power to Relay Board Separately, By using a 12v Adapter.
Sir, I googled about this and I found that Relay board must have a Transistor + Resistor + Diode. Else greater amount of current is transferred back to arduino which hangs it.
And I found Relay Board doesn't have a Resistor and a Transistor.
Should this be a Considerable Reason ?
jack wp
The relay board is not a common one for use with arduino, but the photo showed an IC, which I would assume is the driver (resistor, transistor etc), but don't know for sure.
Runaway Pancake ask if the system works with only one extra board attached, then stops when both are attached?
Ludgy
I see your board works with 12v.
Are you supplying it with enough voltage for it to be stable?
How are you powering your project?
Akshaysarraf
I am powerring the Relay Board Separately with a 12v Supply.
And the Arduino via USB Cable.
Akshaysarraf
CrossRoads
