Topic: Attiny85 and servo (Read 4309 times) previous topic - next topic
WireJunky
I am at a breaking point here.
I have the attiny85 and cunning turtle (servo8bit) library.
Code: [Select]
#include <Servo8Bit.h>
Servo8Bit myServo;  //create a servo object.
  myServo.attach(0);
  delay(1);
  myServo.writeMicroseconds(1500);
There's the code. All it's supposed to do is start up and make the continuous rotation servo spin. It doesn't spin. It doesn't do anything. I'm out of patience. i've been waiting a few months now for an updated servo library to surface but nothing has come up. I need help here.
nicoverduin
Have you looked at the example he used in his GITHUB library? He has written his own delay functions to avoid conflicts with timer0.
see: https://github.com/fri000/Servo8Bit/blob/master/example.cpp
I suspect if you add the delay functions at the end of your code and the forward declaration at the top it might actually work.
Met vriendelijke groet / kindest regards
Nico Verduin
www.verelec.nl
Do not PM me for personal consultancy unless you are willing to pay for it.
WireJunky
Code: [Select]
// Servo8Bit Example code
// Ilya Brutman
#include "Servo8Bit.h"
void delay(uint16_t milliseconds);  //forward declaration to the delay function
int led = 0;
    myServo.attach(0);  //attach the servo to pin PB3
    delay(1);
        for(int pos = 0; pos < 180; pos++)  // goes from 0 degrees to 180 degrees
        {                                   // in steps of 1 degree
            myServo.write(pos);             // tell servo to go to position in variable 'pos'
            delay(1);                      // waits 15ms for the servo to reach the position
        for(int pos = 180; pos > 1; pos--)  // goes from 180 degrees to 0 degrees
    for(uint16_t i = 0; i < milliseconds; i++)
        delayMicroseconds(1000);
}//end delay
Like this? I try this and I get an error saying "call of overloaded 'delay(int)' is ambiguous".
nickgammon
Well, call it myDelay or some different name.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
nicoverduin
And while you aare at it, may as well add his function of delayMicroSeconds also:
Code: [Select]
void delayMicroseconds(uint16_t us)
#if F_CPU >= 16000000L
    // for the 16 MHz clock on most Arduino boards
    // for a one-microsecond delay, simply return. the overhead
    // of the function call yields a delay of approximately 1 1/8 us.
    if (--us == 0)
        return;
    // the following loop takes a quarter of a microsecond (4 cycles)
    // per iteration, so execute it four times for each microsecond of
    // delay requested.
    us <<= 2;
    // account for the time taken in the preceeding commands.
    us -= 2;
#else
    // for the 8 MHz internal clock on the ATmega168
    // for a one- or two-microsecond delay, simply return. the overhead of
    // the function calls takes more than two microseconds. can't just
    // subtract two, since us is unsigned; we'd overflow.
    if (--us == 0)
        return;
    if (--us == 0)
        return;
    // the following loop takes half of a microsecond (4 cycles)
    // per iteration, so execute it twice for each microsecond of
    // delay requested.
    us <<= 1;
    // partially compensate for the time taken by the preceeding commands.
    // we can't subtract any more than this or we'd overflow w/ small delays.
    us--;
#endif
    // busy wait
    __asm__ __volatile__ (
        "1: sbiw %0,1" "\n\t" // 2 cycles
        "brne 1b" : "=w" (us) : "0" (us) // 2 cycles
}//end delayMicroseconds
Nico Verduin
www.verelec.nl
nickgammon
And what's with
all the blank lines in your code?
It doesn't make it any more readable.
WireJunky
Code: [Select]
// Ilya Brutman
void mydelay(uint16_t milliseconds);  //forward declaration to the delay function
int led = 0;
    delay(1);
}//end delay
I put it as mydelay, but still no luck.
By the way, should I be using the attiny on a 1mhz or 8 mhz clock?
ky9129
Does it works with another arduino? Double check connections.
However, I have heard that attiny is not fully compatible with arduino - few libraries/ functions might not work
WireJunky
The connections are simple.
http://farm7.static.flickr.com/6065/6121376853_e8355afe33.jpg
The servo is hooked into the proper pins on the programmer.
For some reason though, the servo spins on pin 1 of the attiny, but that's all it does. Spin.
Code: [Select]
// Ilya Brutman
int led = 0;
    delay(1);
}//end delay
How hard is it to write a library? I think it may be quicker for me to write one instead of waiting for cunningturtle to update his.
nickgammon
Code: [Select]
// Ilya Brutman
int led = 0;
    delay(1);   // <---------- mydelay (1);
Yes but you have to call mydelay, not delay.
WireJunky
Code: [Select]
// Ilya Brutman
int led = 0;
What do you mean by call mydelay?
Forgive my ignorance, I'm a beginner in this stuff.
nickgammon
Code: [Select]
    delay(1);
This line calls (invokes) the function. Thus if you are renaming delay as mydelay you have to do it everywhere in the sketch. You haven't done that.
WireJunky
Code: [Select]
    delay(1);
// Ilya Brutman
int led = 0;
  myServo.attach(1);  //attach the servo to pin PB3
    mydelay(1);
            mydelay(1);                      // waits 15ms for the servo to reach the position
}//end delay
Like this? I must be missing something, this doesn't work either.
nickgammon
Can you put your code in code tags please, and post your error message?
Read this before posting a programming question
Quote
this doesn't work
... doesn't tell us much. It doesn't compile? It doesn't run?
WireJunky
Quote
this doesn't work
Code: [Select]
// Ilya Brutman
int led = 0;
    mydelay(1);
}//end delay
I don't get an error message. By 'it doesn't work' I mean that when I power it up, all the servo does is spin in a circle. Even with standard servo it does nothing. And now when I try to upload it doesn't even upload.
