Topic: detect voltage project (Read 3507 times) previous topic - next topic
max1
I'm using a arduino mega 2560, with a LCD. Right now the program i have displays four boxes with four different names. What i want to be able to do is if you select one of the names it can tell you if the person is considered online or offline. The status i want to set is if its receiving more then 5 volts its online less is offline. I have the wiring done on a breadboard to give 5 volts. Now i understand analogread in the code and write it by using if/else statements, but i'm new to programming so i'm not sure how to go about specifically how to write it. Any advice or suggestions would be appreciated, thank you. I included the code below.
#include <UTFT.h>
#include <UTouch.h>
#include <UTFT_Buttons.h>
// Declare which fonts we will be using
extern uint8_t SmallFont[];
extern uint8_t BigFont[];
extern uint8_t Dingbats1_XL[];
// Set up UTFT...
// Set the pins to the correct ones for your development board
// Standard Arduino 2009/Uno/Leonardo shield   : <display model>,19,18,17,16
// Standard Arduino Mega/Due shield            : <display model>,38,39,40,41
// CTE TFT LCD/SD Shield for Arduino Due       : <display model>,25,26,27,28
// Standard chipKit Uno32/uC32                 : <display model>,34,35,36,37
// Standard chipKit Max32                      : <display model>,82,83,84,85
// AquaLEDSource All in One Super Screw Shield : <display model>,82,83,84,85
// Remember to change the model parameter to suit your display module!
UTFT          myGLCD(ITDB32S,38,39,40,41);
// Set up UTouch...
// Standard Arduino 2009/Uno/Leonardo shield   : 15,10,14,9,8
// Standard Arduino Mega/Due shield            : 6,5,4,3,2
// CTE TFT LCD/SD Shield for Arduino Due       : 6,5,4,3,2
// Standard chipKit Uno32/uC32                 : 20,21,22,23,24
// Standard chipKit Max32                      : 62,63,64,65,66
// AquaLEDSource All in One Super Screw Shield : 62,63,64,65,66
UTouch        myTouch(6,5,4,3,2);
// Finally we set up UTFT_Buttons :)
UTFT_Buttons  myButtons(&myGLCD, &myTouch);
int sensorPin = A0;    // select the input pin for the potentiometer
int ledPin = 13;      // select the pin for the LED
int sensorValue = 0;  // variable to store the value coming from the sensor
  pinMode(ledPin, OUTPUT);   // sets the pin as output
  myGLCD.InitLCD();
  myGLCD.clrScr();
  myGLCD.setFont(SmallFont);
  myTouch.InitTouch();
  myTouch.setPrecision(PREC_MEDIUM);
  myButtons.setTextFont(BigFont);
  myButtons.setSymbolFont(Dingbats1_XL);
  int but1, but2, but3, but4, butX, butY, pressed_button;
  boolean default_colors = true;
  but1 = myButtons.addButton( 10,  40, 100,  50, "Mark");
  but2 = myButtons.addButton( 10,  130, 100,  50, "Carl");
  but3 = myButtons.addButton( 190, 40, 100,  50, "Ricky");
  but4 = myButtons.addButton( 190, 130, 100,  50, "Sarah");
  butX = myButtons.addButton(279, 199,  40,  40, "Y", BUTTON_SYMBOL);
  butY = myButtons.addButton(  0, 199, 40,  40, "w", BUTTON_SYMBOL /*| BUTTON_SYMBOL_REP_3X*/);
  myButtons.drawButtons();
  myGLCD.print("STMS CONFERENCE CALL", 80, 10);
  myGLCD.setColor(VGA_WHITE);
  myGLCD.setBackColor(VGA_BLACK);
  myGLCD.print("None    ", 110, 220);
  while(1)
    if (myTouch.dataAvailable() == true)
      pressed_button = myButtons.checkButtons();
      if (pressed_button==butX)
        if (myButtons.buttonEnabled(but4))
          myButtons.disableButton(but4, true);
          myButtons.enableButton(but4, true);
      else if (pressed_button==butY)
        if (default_colors)
          myButtons.setButtonColors(VGA_RED, VGA_RED, VGA_RED, VGA_BLUE, VGA_WHITE);
          myButtons.relabelButton(butY, "w");
          default_colors=false;
          myButtons.setButtonColors(VGA_WHITE, VGA_GRAY, VGA_WHITE, VGA_RED, VGA_BLUE);
          default_colors=true;
      if (pressed_button==but1)
        myGLCD.print("MAX", 110, 220);
      if (pressed_button==but2)
        myGLCD.print("AHMAD", 110, 220);
      if (pressed_button==but3)
        myGLCD.print("STEVE", 110, 220);
      if (pressed_button==but4)
        myGLCD.print("JOHN", 110, 220);
      if (pressed_button==-1)
  // read the value from the sensor:
  sensorValue = analogRead(sensorPin);
  // turn the ledPin on
  digitalWrite(ledPin, HIGH);
  // stop the program for <sensorValue> milliseconds:
  delay(sensorValue);
  // turn the ledPin off:
  digitalWrite(ledPin, LOW);
  // stop the program for for <sensorValue> milliseconds:
  delay(sensorValue);
mmcp42
start by putting your code inside
[ code]
[/ code]
(but without the spaces
then we can read it properly)
there are only 10 types of people
them that understands binary
and them that doesn't
