I was recently working on my latest project. A GameBoy Advance cartridge reader. I currently have no problems at all reading the actual data from the ROM chip but I still need to transfer the data through the serial interface and store these in a file on the computer. The data transfer should be completely lossless and there should be no errors in the file lateron and I'm having big trouble to realize that since I can't just write all the bytes to the serial interface because there might be errors in the transfer and could possibly cause issues later.
So my question is: Is there any common protocol or even librarys out there that help me doing that?
I previously used C# and the serial port class to recieve data but I also have lots of trouble using that correctly since I'm to really able to program anything useful without using "loop waits" when it comes to wait for serial data to be avaiable at the computer.
Back in the eighties, people used lossy serial connections to move files all the time. There are a number of protocols that you could use:
I suspect that XModem would be the way to go. The protocol is fairly simple, and I suspect with a little searching you could find a good implementation.
// This function is called each time the xmodem protocol needs a
// new block to send.
void get_next_xmodem_block() {
// Our virtual file is two blocks (256 bytes) long
if(blknum < 3) {
// If we have a next block to send, fill the buffer
for(int i = 0; i < 128; i++) data = 'A' + (i % 26);
// And assign the address.*
block = data;*
} else {*
// Assign NULL to indicate that we've already sent the last*
for(int i = 0; i < 128; i++) {*
_ Serial.write(block*);_ _ checksum += block; } Serial.write(checksum); } } } void loop() { // Thumb twiddling* } [/quote] I've tested this using minicom as the receiver on my linux box, and it works. You should know that this is a very naive implementation: - It uses checksums (which are slightly less robust when compared to CRCs) - It doesn't accept cancel messages (You'll notice the define for XMODEM_CAN doesn't get used anyplace - It only sends the file once, and then effectively hangs, sending at every subsequent request - And it probably ignores half a dozen other corner cases Hope this helps, Peter._
