Topic: virus/trojan malware usb transport. (Read 3539 times) previous topic - next topic
cjdelphi
Hackers are merely leaving usb infected sticks around which copy to the victim's machine and copy to any new usb sticks discovered...
Here's the catch, these infected sticks are starting to see code to communicate and upload to microcontrollers in one example infecting via the stick inside a nuclear station where it dpread machine to machine looking for hardware controllers then speeding up the servos or slowing thrm down to destroy rods i think...
So trojans infecting arduino's ? :o
radman
You seemto be talking about the stuxnet worm which could attack Programmable Logic Controllers (PLC)s. It seems to be very sophisticated and required large resources to develop.
USBs are now spreading malware in the same way floppy disks used to.
I can see the PC on which you run your IDE getting infected though I doubt the arduino could get infected in any meaningful way i.e. somebody being able to control something.
robtillaart
Maybe we can make a sketch for an Arduino with USB shield as Virus/malware detector
- simple check if it has autorun features and report them on an LCD (red led /green led)
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
wizdum
And those PLCs were usually plugged into computers running unpatched or pirated versions of Windows XP.  :smiley-eek:
Its a really cool attack vector though. Just buy a bunch of bulk USB drives on ebay, load virus, sprinkle them around in the parking lot of "Competing Company A", and then profit. Smart sysadmins disable auto-run and USB ports though.
The problem is, a lot of these older industrial control programs only run on old operating systems. They cost so much to initially develop, that the company doesn't want to pay a programmer to make a new controller. It wouldn't be too big of a deal, but people can't live without Facebook and Twitter now, so these machines are plugged into the local network so their users can screw around all day instead of working.
MAS3
Quote from: wizdum
That reads as the words of some spokesman of Microsoft trying to convince the world to buy their latest products (over and over and over again).
Unpatched computers are no problem whatsoever and are more or less standard in SCADA systems that are not connected to an other than the internal network.
That means no internet connection whatsoever.
Internet has no business in nuclear reactor control rooms.
Patching systems that are part of critical (nuclear) processes is something that has to be tested extensively before applying that patch.
You won't be able to do that every "patch tuesday".
So if the base is stable, and you have no external (network) connections why would you need to patch/update of which you don't know what that will do with stability.
If you do need to backup or update/restore the SCADA application, you should use media that is only used for that goal and that is loaded from a system that meets the same conditions or is up to date.
Have a look at "blink without delay".
Did you connect the grounds ?
Je kunt hier ook in het Nederlands terecht: http://arduino.cc/forum/index.php/board,77.0.html
robtillaart
Quote
Did you check Homer Simpson? ;)
More serious, I think you mean:
The computers in the control room controlling the nuclear reactor should never be connected to the Internet.
There may be additional computers for communication documentation simulation etc
Rob Tillaart
wizdum
Quote from: wizdum
I have no love for MS, so take that crap elsewhere. One of the early patches for Windows XP removed the USB Autorun "Feature". So yes, a Patch Tuesday patch would have prevented that. There are more complex auto-execution hacks, but they still require the user to run them manually (and hopefully people working in these places no not to run random .exe files they find on a thumbdrive in the parking lot). Windows XP is 12 years old. Is 12 years enough time to "test extensively before applying that patch"? As I said in my previous post, these systems were never supposed to be online in the first place, but they are placed on the public network to make users happy. The problem is threefold: lazy sysadmins, cheap upper management, and outdated software. Obviously jumping on the RTM version of Windows 8.1 is a bad idea, but how about trying an OS that was created in THIS decade? Or better yet, get rid of Windows entirely and use a stripped down variant of Linux with no GUI or USB support.
AWOL
#7
Aug 21, 2013, 06:12 pm Last Edit: Aug 21, 2013, 06:19 pm by AWOL Reason: 1
Quote
these infected sticks are starting to see code to communicate and upload to microcontrollers PLCs in one example infecting via the stick inside a nuclear station uranium enrichment plant where it dpread [sic] machine to machine looking for hardware controllers then speeding up the servos gas centrifuges or slowing thrm[sic] down to destroy rods/ disrupt yield i think...
Close, but no cigar.
(old news, BTW)
The stuxnet dossier is a good read.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
Osgeld
I have dozens of PLC's under my control at work, none of them require attachment to a PC, and when they do its typically via a GPIO interface (ISA PCI USB whatever) sending single bits on single channels
not saying that machines dont use direct computer connections over some bus, but its typically a very simple bus, much like an arduino ... so unless your saving raw data from a plc, packing it up and running it as a windows exe, its not that big of a deal
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
wizdum
#9
Aug 22, 2013, 06:17 pm Last Edit: Aug 22, 2013, 06:20 pm by wizdum Reason: 1
I'm not sure how these were interfaced with a Windows PC, but they were able to change some of the instructions for the PLCs from the Windows environment. Wikipedia says they used this: http://en.wikipedia.org/wiki/WinCC.
Quote
Stuxnet installs malware into memory block DB890 of the PLC that monitors the Profibus messaging bus of the system.[40] When certain criteria are met, it periodically modifies the frequency to 1410 Hz and then to 2 Hz and then to 1064 Hz, and thus affects the operation of the connected motors by changing their rotational speed.[46] It also installs a rootkit - the first such documented case on this platform - that hides the malware on the system and masks the changes in rotational speed from monitoring systems.
http://en.wikipedia.org/wiki/Stuxnet
The other kinds of SCADA "vulnerabilities" are as you say, not a big deal. The one that comes to mind is a nuclear power plant in France. The system is on the internet, and you can access it remotely using default telnet credentials. The only thing it gets you is a page of statistics. You can see their total power output, output per reactor, temperatures, stuff like that.
