Topic: Arduino Controller Pro profiles and sketches (Read 11413 times) previous topic - next topic
BobbyD
here is the last part of the " Home_Control " sketch:
Code: [Select]
if (c == '\n') {
          currentLineIsBlank = true;
        else if (c != '\r') {
          currentLineIsBlank = false;
    client.stop();
void action(int x, EthernetClient client)
  if (x == 01)
  {client.print (content_main_top);
   client.println(S1);
   Serial.println(S1);
   irsend.sendNEC(0xC1A28877,32); // NEC Sherwood Receiver Power ON
if (x == 02)
   client.println(S2);
   Serial.println(S2);
   irsend.sendNEC(0xC1A2B847,32); // NEC Power OFF
if (x == 03)
   client.println(S3);
   Serial.println(S3);
   irsend.sendNEC(0xC1A2C03F,32); // NEC FM
if (x == 04)
   client.println(S4);
   Serial.println(S4);
   irsend.sendNEC(0x45BA38C7,32); // NEC CD POWER toggle
if (x == 05)
   client.println(S5);
   Serial.println(S5);
   irsend.sendNEC(0xC1A2D02F,32); // NEC cd player
if (x == 06)
   client.println(S6);
   Serial.println(S6);
   irsend.sendNEC(0x45BA52AD,32); // NEC Random
if (x == 07)
   client.println(S7);
   Serial.println(S7);
   irsend.sendNEC(0xC1A250AF,32); // NEC Ipod
if (x == 8)
   client.println(S8);
   Serial.println(S8);
   valuegreen = 0;//
   analogWrite(barLight, valuegreen);                                //  Bob added to get bar light to dim OCT 12,2013
   client.print (content_main_top);                                  // set the background an text color of the webview in the app
   client.print("BarLight is now: ");
   client.print(valuegreen);                                         // print the value to the android application
if (x == 9)
   client.println(S9);
   Serial.println(S9);
   valuegreen = 220;//
   client.print(valuegreen);                                        // print the integer value to the android application
if (x == 10)
   client.println(S10);
   Serial.println(S10);
   valuered = 0;                                                    // give a value of 0 so curioLight is off
   analogWrite(curioLight, valuered);                               // write redvalue of 0 to curioLight
   client.print("CurioLight is now: ");
   client.print(valuered);                                          // print the value to the android application
if (x == 11)
   client.println(S11);
   Serial.println(S11);
   valuered = 160;
if (x == 20)
   client.println(S20);
   Serial.println(S20);
   valueblue = 0;
   analogWrite(benchLight, valueblue);
   client.print("BenchLight is now: ");
   client.print(valueblue);                                       // print the value to the android application
if (x == 21)
   client.println(S21);
   Serial.println(S21);
   valueblue = 100;
if (x == 22)
   client.println(S22);
   Serial.println(S22);
   client.print("CurioLight: ");
   client.print(valuered);                                        // print the integer value to the android application
   client.print("BarLight: ");
   client.print("BenchLight: ");
if (x == 23)
   client.println(S23);
   Serial.println(S23);
   valuered = 0;
   valuegreen = 0;
   valueblue = 0;//
   analogWrite(benchLight, valueblue);                            //  Bob added to get bar light to dim OCT 12,2013
  if (x == 24)
   client.println(S24);
   Serial.println(S24);
   valuered = 180;
   valuegreen = 200;//
   valueblue = 100;
  if (x == 100)  //Default action
    client.print ("Default message");
    Serial.println("Default");
  if (x == 404)
    client.println(S404);
    Serial.println(S404);
  x=0;
BobbyD
Here is the screenshot of the " Home_Control " as viewed on my Android tablet.Note the values for each light is shown at the top of the screen.
Bobby_D
redcell
Great app I bought it in the google play store..
is it possible to have more then the 32 available buttons?
I could use like 50 to 60 buttons to controll all of my devices at home.
On my Nexus 7 tablet there is plenty of room for more buttons then the available 32....
BobbyD
redcell ,
  Hello again! Keep in mind you can have up to 8 profiles ...so over 200 buttons if you look at it that way. I have 3 separate ethernet boards and have 3 profiles . There is so much expandability as well with this app that you can have several profiles with the same IP and MAC address .It is then the string you send and decode with your Arduino program that provides you the extra button functionality.
   I think Marque is doing some great work with his apps and he is helping to bring Arduino and Android to the people to use in some very creative ways .
BobbyD
Arjankp
If i use the script as mentioned i get an error:
avrdude: ser_open(): can't open device "/dev/cu.wchusbserial14220": No such file or directory
Is there also an example for beginners:
First a switc
Then an output
Because this is going fast.
Kind Regards,
Arjan
