Topic: LCD(JHD 162A) Interface (Read 7911 times) previous topic - next topic
dev_000
I bought a JHD 162A LCD unit. but simply cant interface it with arduino. tried every possible thing but cant get it to display anything. I saw many posts in this forum which led to nothing...  :-[
I connected it exactly like this and ran the hello world code with edit as they gave. http://www.ladyada.net/learn/lcd/charlcd.html
checked and rechecked connections that is not the problem it seems. I tried liquidcrystal as well as LCD4Bit libraries but both arent working.
backlights
Someone Plz tell me how to do it... becoz i have bought some 20 lcds of the same type. tried different leds but got nothing...
Can someone help.... :'(
jrraines
looks like it is a standard 16x2 LCD that should be compatible with the instructions you cited:
http://iamsuhasm.wordpress.com/tutsproj/using-lcds/
what do you see when you follow the tutorial? a photo of the wiring/ screen might be helpful.
mrmeval
http://www.electrokit.se/download/JHD162A%20SERIES.pdf
KS0066 which is a clone of the hitachi part
http://www.systronix.com/access/Systronix_20x4_lcd_brief_data.pdf
http://www.avrbeginners.net/ Click on interfacing examples then read all the subtree. The introduction is worth reading the rest is not specific to the Arduino but it is to atmel.
floresta
#3
Jun 30, 2010, 01:42 am Last Edit: Jun 30, 2010, 01:42 am by floresta Reason: 1
Quote
I connected it exactly like this ...
and ran the hello world code with edit as they gave. ...
checked and rechecked connections ...
One or more of these is wrong.
Quote
Can someone help
Not without your code, a photo of your connections, and a description or photo of what is or is not displayed.
Don
dev_000
seriously its exactly same as given here
connections have problem i checked it again.
i edited helloworld with the foll as mentioned in tutorial
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
Still not working.... it isnt showing anything...
jrraines
When you adjust the contrast potentiometer you don't see squares on the display? Here's an example of that:
http://twitpic.com/3dqom
floresta
#6
Jun 30, 2010, 12:44 pm Last Edit: Jun 30, 2010, 12:48 pm by floresta Reason: 1
Quote
seriously its exactly same as given here ...
These are mutually exclusive.
If you really want some help then you are going to have to give us something to work with as I mentioned in reply #3.
We need a copy (cut and paste) of the code that you used, not a reference to the code that you think you used.  We also need a photo of the connections that you actually made, not a reference to the connections that you think you made.
Don
dev_000
thanx guys got it working.... just turned on the power and voila... :D i still dont knw wat was trouble though...  :) so for the last time JHD162a will work with arduino  ;)
