Topic: need some help with code (Read 13526 times) previous topic - next topic
MillerJLee98579
so ive been working on this robot im building ive double checked my wiring and i think the problem im having is in the code because my ping sensor is not working
Code: [Select]
/*MAEP 2.0 Navigation
by Noah Moroze, aka GeneralGeek
This code has been released under a Attribution-NonCommercial-ShareAlike license, more info at http://creativecommons.org/licenses/
PING))) code by David A. Mellis and Tom Igoe http://www.arduino.cc/en/Tutorial/Ping
Edited by: Jason Miller for Project KITT
#include <Servo.h> //include Servo library
#include <LiquidCrystal.h> //include lcd library
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
const int RForward = 0;
const int RBackward = 180;
const int LForward = RBackward;
const int LBackward = RForward;
const int RNeutral = 90;
const int LNeutral = 90; //constants for motor speed
const int pingPin = 4;
const int dangerThresh = 5; //threshold for obstacles (in inches)
int leftDistance, rightDistance; //distances on either side
Servo panMotor;
Servo leftMotor;
Servo rightMotor; //declare motors
long duration; //time it takes to recieve PING))) signal
  lcd.begin(16, 2);
  lcd.print("Hello Jason");
  lcd.clear();
  lcd.print("Activating KITT");
  lcd.clear();
  lcd.print("KITT Online");
  rightMotor.attach(5);
  leftMotor.attach(6);
  panMotor.attach(3); //attach motors to proper pins
  panMotor.write(90); //set PING))) pan to center
  int distanceFwd = ping();
  if (distanceFwd>dangerThresh) //if path is clear
    leftMotor.write(LForward);
    rightMotor.write(RForward); //move forward
    lcd.print("Forward");
  else //if path is blocked
    leftMotor.write(LNeutral);
    rightMotor.write(RNeutral);
    panMotor.write(0);
    rightDistance = ping(); //scan to the right
    lcd.print("Scan Right");
    panMotor.write(180);
    delay(700);
    leftDistance = ping(); //scan to the left
    lcd.print("Scan Left");
    panMotor.write(90); //return to center
    delay(100);
    compareDistance();
void compareDistance()
  if (leftDistance>rightDistance) //if left is less obstructed
    leftMotor.write(LBackward);
    rightMotor.write(RForward); //turn left
    lcd.print("Turn Left");
  else if (rightDistance>leftDistance) //if right is less obstructed
    rightMotor.write(RBackward); //turn right
    lcd.print("Turn Right");
   else //if they are equally obstructed
    rightMotor.write(RBackward); //turn 180 degrees
    lcd.print("Turn 180");
long ping()
  // Send out PING))) signal pulse
  long duration, inches;
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  //Get duration it takes to receive echo
  pinMode(pingPin, INPUT);
  duration = pulseIn(pingPin, HIGH);
  inches = microsecondsToInches(duration);
  lcd.print(inches);
  lcd.print("in to obstacle");
  delay(100);
  lcd.clear();
  delay(100);
  long microsecondsToInches(long microseconds)
  return duration / 29 / 2;
MillerJLee98579
also all 3 servos im using are on a seperate power supply and not running off of the arduino
robtillaart
Quote
You could strip your sketch to the ping sensor only and try to check its working?
A quick look at the code did show one thing:
pulseIn() returns unsigned long IIRC so you have to adjust types at some points. but that should not got your sensor failing immediately.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
aarondc
I didn't read anywhere what the problem actually was?
MillerJLee98579
ok i tested the ping sensor by itself and it works the problem i m having is when everything is running my danger thresh hold does not appear to be doing what its supposed to (I.E. the robot is constantly moving forward and not stopping)
MillerJLee98579
also it is only displaying 0inches to obstacle on my lcd screen when the full code is running when just the ping code with print is running everything works fine please can someone help me figure out where my mistake is so i can get this running right
MillerJLee98579
ok tested ping sensor by itself and it works tested ping sensor and servo code without the lcd screen and they work i add in the code for the lcd screen and nothing works properly can someone please help me figure out this problem
Code: [Select]
Edited by Jason Miller for Project KITT
const int irPin = 0;  //Sharp infrared sensor pin
const int dangerThresh = 5; //threshold for obstacles (in cm)
Servo panMotor;
Servo leftMotor;
  lcd.begin(16, 2);
  lcd.clear();
  lcd.clear();
    panMotor.write(0);
    delay(700);
    delay(100);
    compareDistance();
long ping()
  lcd.print(inches);
  delay(100);
  lcd.clear();
  delay(100);
  return duration / 74 / 2;
ive been racking my brain on this for the last couple of days and cannot figure out why it isnt working
wildbill
You might want to post the working code too. However, one issue I see is that there should be a return inches; at the end of the ping function.
MillerJLee98579
Code: [Select]
[code]ok the first code listed is the working code with everything but the lcd screen the second code is the working code for just the ping sensor with lcd screen
I basically merged the two different codes into one and thats when all the problems happened
const int dangerThresh = 10; //threshold for obstacles (in cm)
Servo panMotor;
Servo leftMotor;
    panMotor.write(0);
    delay(700);
    delay(100);
    compareDistance();
long ping()
  //Convert duration into distance
  [/code]
Code: [Select]
  lcd.begin(16, 2);
  lcd.clear();
  lcd.print(inches);
  delay(100);
  lcd.clear();
  delay(100);
  return microseconds / 74 / 2;
wildbill
Yup, the difference is the missing return statement.
MillerJLee98579
ok so how would i work that in?
wildbill
Put this at the end of your ping function:
Code: [Select]
return inches;
MillerJLee98579
ok i added the line you suggested and now it still doesnt display the distance on the screen and just spins in circles
Code: [Select]
Servo panMotor;
Servo leftMotor;
  lcd.begin(16, 2);
  lcd.clear();
  lcd.clear();
    panMotor.write(0);
    delay(700);
    delay(100);
    compareDistance();
long ping()
  lcd.print(inches);
  delay(100);
  lcd.clear();
  delay(100);
  return inches;
MillerJLee98579
also after adding that line the screen refresh rate slowed down drastically
wildbill
I assume that the number of inches returned is always less than your danger threshold, so your comparedistance function with its delays are being called, slowing the refresh down. I'd clear the LCD before you print to it, not afterwards. Right now you have a 10th of a second to see what the ping measurement is. Try making the delay there longer and verify what you're getting from the ping, which I suspect will be less than 5.
