Topic: FastShiftOut with Print interface (experimental) (Read 3876 times) previous topic - next topic
robtillaart
Aug 23, 2013, 12:05 am Last Edit: Jan 25, 2014, 07:23 pm by robtillaart Reason: 1
Find below an experimental class that implements a FastShiftOut Class which is derived from the Print class.
This means that all print and println interfaces are available to FSO, including printing of strings, floats and ints.
The class does not implement the latch signal (e.g. to be used for one or more 74HC595)
The class is not tested so use at your own risk ;)
as always comments and remarks are welcome.
FastShiftOut.h
Code: (experimental) [Select]
//    FILE: FastShiftOut.h
//  AUTHOR: Rob Tillaart
// VERSION: 0.1.03
// PURPOSE: shiftout that implements the Print interface
//     URL:
// Released to the public domain
#ifndef FastShiftOut_h
#define FastShiftOut_h
#if defined(ARDUINO) && ARDUINO >= 100
 #include "Arduino.h"
#else
 #include "WProgram.h"
#endif
#define FASTSHIFTOUT_LIB_VERSION "0.1.03"
#include "Print.h"
class FastShiftOut : public Print
 public:
FastShiftOut(uint8_t, uint8_t, uint8_t);
   size_t write(uint8_t);
   int read(void);
 private:
   uint8_t _bitorder;
   int _value;
uint8_t _databit;
   volatile uint8_t *_dataout;
uint8_t _clockbit;
   volatile uint8_t *_clockout;
#endif
// -- END OF FILE --
FastShiftOut.cpp
//    FILE: FastShiftOut.cpp
// VERSION: 0.1.03
//     URL:
#include "FastShiftOut.h"
// Constructor
// prepares the digitalWrite()
FastShiftOut::FastShiftOut(uint8_t datapin, uint8_t clockpin, uint8_t bitOrder)
   _bitorder = bitOrder;
   _value = -1;
   pinMode(datapin, OUTPUT);
   pinMode(clockpin, OUTPUT);
   // uint8_t _datatimer  = digitalPinToTimer(datapin);
   // if (_datatimer != NOT_ON_TIMER) turnOffPWM(_datatimer); TODO
uint8_t _dataport   = digitalPinToPort(datapin);
   _dataout = portOutputRegister(_dataport);
_databit = digitalPinToBitMask(datapin);
   // uint8_t _clocktimer = digitalPinToTimer(clockpin);
   // if (_clocktimer != NOT_ON_TIMER) turnOffPWM(_clocktimer);
uint8_t _clockport  = digitalPinToPort(clockpin);
   _clockout = portOutputRegister(_clockport);
_clockbit   = digitalPinToBitMask(clockpin);
// write() must implement the virtual write of Print class
size_t FastShiftOut::write(uint8_t data)
   _value = data;
   for (uint8_t i = 0; i < 8; i++)
       uint8_t v;
       if (_bitorder == LSBFIRST)   v = !!(_value & (1 << i));
       else                        v = !!(_value & (1 << (7 - i)));
       uint8_t oldSREG = SREG;
       cli();
       if (v == LOW)  *_dataout &= ~_databit;
       else           *_dataout |= _databit;
       *_clockout |= _clockbit;
       *_clockout &= ~_clockbit;
       SREG = oldSREG;
   return 1;
// reads back the last value written.
int FastShiftOut::read()
   return _value;
FSO001.ino, tests some performance compared to standard shiftOut()
FastShiftOut FSO(12, 13, LSBFIRST);
 Serial.println("Start FSO");
 unsigned long start = millis();
 for (int i=0; i<10000; i++)
   FSO.write(0x55);
 Serial.println((millis() - start)/10.0, 4);
 start = millis();
   FSO.write(0x55);
   FSO.write(0x55);
 start = millis();
   shiftOut(12, 13, 0x55, LSBFIRST);
 start = millis();
 Serial.println("test print interface");
 start = millis();
   FSO.println("Hello world");
 start = millis();
   FSO.println(1357);
 start = millis();
   FSO.println(3.14159265, 4);
 Serial.println("done");
output:
Start FSO
61.3000
122.4000
114.8000
229.5000
812.8000
403.8000
572.5000
done
The FSO Class is almost 2x faster than normal shiftOut() [times in uSec]
Times for strings, ints and floats are approx. as expected. (add newline chars too)
update:
latest version check - https://github.com/RobTillaart/Arduino/tree/master/libraries -
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
robtillaart
Note: the timings found above might be hard to reproduce as my print.cpp and print.h contains several speed ups (including experimental).
These are discussed in this thread - http://forum.arduino.cc/index.php?topic=167414.0 -
Rob Tillaart
robtillaart
speed optimized version of the write, ~twice as fast, but it disables interrupts for the whole byte; and its larger ..
(replace in lib above)
Code: (highly experimental) [Select]
// approx 32 us / byte
    _value = data;
    // prep masks
    uint8_t dm1 = *_dataout | _databit;
    uint8_t dm0 = *_dataout & ~_databit;
    uint8_t cm1 = *_clockout | _clockbit;
    uint8_t cm0 = *_clockout & ~_clockbit;
    cli();
        for (uint8_t m = 0x01; m != 0x80; m <<= 1)
            if (_value & m) *_dataout = dm1;
            else           *_dataout = dm0;
            *_clockout = cm1;
            *_clockout = cm0;
        for (uint8_t m = 0x80; m > 0; m >>= 1)
            *_clockout = cm1;
            *_clockout = cm0;
    SREG = oldSREG;
    return 1;
use at own risk ;)
Rob Tillaart
Khalid
Rob,
Thanks for this new approach in Shiftout. I shall check how can i utilize it in my Graphical waterfall project.
Regards
Simply...You can't afford me..
Author Of:
http://my-woodcarving.blogspot.com/
http://www.free3dscans.blogspot.com/
http://my-diysolarwind.blogspot.com/
Oops..some one gave me Karma...:)
robtillaart
latest version can be found here - https://github.com/RobTillaart/Arduino/tree/master/libraries -
Rob Tillaart
Khalid
Thank you for the generosity and sharing:) I shall come back and report..
Regards
Author Of:
robtillaart
#6
Apr 27, 2017, 12:19 am Last Edit: Apr 27, 2017, 12:19 am by robtillaart
latest version 0.1.5 can be found here - https://github.com/RobTillaart/Arduino/tree/master/libraries -
major improvement in performance by more efficient masking of bits.
Time dropped from 42.72 usec to 28.83 usec per byte.
Code: ("performance notes") [Select]
tests done with IDE 1.8.1
example fastShiftOut: 0.1.5
Performance - time in us
FastShiftOut1: 29.76
FastShiftOut2: 58.59
        Delta: 28.83
Standard shiftOut1: 90.80
Standard shiftOut2: 181.00
             Delta: 90.20
Test print interface
println("Hello world"): 417.08
println(1357): 353.00
println(3.14159265, 4): 766.28
done ...
example fastShiftOut: 0.1.04
FastShiftOut1: 43.66
FastShiftOut2: 86.38
        Delta: 42.72
Standard shiftOut1: 90.79
             Delta: 90.21
println("Hello world"): 597.68
println(1357): 436.44
println(3.14159265, 4): 877.48
done ...
Rob Tillaart
