Topic: change ADC clock (Read 5141 times) previous topic - next topic
pedrolopes746
hello,
I needed set sampling frequency = 25 KHz .
I used the sequinte code:
int ACTUAL_ADC_CLK;
analogReadResolution(12);
//uint32_t adc_init(Adc *p_adc, const uint32_t ul_mck, const uint32_t ul_adc_clock, const uint32_t ul_startuptime)
// ul_mck Main clock of the device (value in Hz).
// ul_adc_clock Analog-to-Digital conversion clock (in Hz).
//ul_startuptime ADC startup time value (value in us).
adc_init(ADC, SystemCoreClock, 25000, 12);
//return adc clock
  ACTUAL_ADC_CLK = adc_get_actual_adc_clock(ADC, SystemCoreClock);
  Serial.println(ACTUAL_ADC_CLK);
  while (1) {}
The program output is 291666 Hz (292KHz).
groundFungus
Quote
ACTUAL_ADC_CLK is an int.  How can an int be 291666?
pedrolopes746
I do not know
the program must return the value of adc clock in Hz, ie should return 25000 and not 291666.
removing the following line of code (adc_init (ADC, SystemCoreClock, 25000, 12);) the return value would be 21000000 since it is the maximum frequency adc.
Gericom
Quote
Why not? An int is 32 bit.
Subscribe my youtube channel: http://www.youtube.com/user/MKDS3
pedrolopes746
any idea how sampling frequency to a specific value ?
Gericom
I think you have to set the ul_mck to 25000 and ul_adc_clock to SystemCoreClock / 2
pedrolopes746
It doesn't work.
Gericom
It doesn't work.
What is the frequency if you do that?
pedrolopes746
groundFungus
Quote
Quote from: groundfungus on Today at 02:12:41 am
Quote
int is 2 bytes.  16 bit, ±32K.  Long is 4 bytes.  32 bits.
Gericom
Quote
Quote
I thought that was on an original arduino. On a due int is 32bit as far as I know.
pedrolopes746
I think the clock in adc arduino due is limited to 164kHz.
the manual of arduino due says:
"The ADC clock range is between MCK/2, if PRESCAL is 0, and MCK/512, if PRESCAL is set to
255 (0xFF). PRESCAL must be programmed in order to provide an ADC clock frequency
according to the parameters given in the product Electrical Characteristics section."
Palliser
Code: [Select]
  ACTUAL_ADC_CLK = adc_get_actual_adc_clock(ADC, SystemCoreClock/11.6666);
pedrolopes746
the output is 1800120
I wanted 25000
the maximum I can get is 164000.
Palliser
I overlooked you quote from the Atmel's manual but I believe you already gave yourself the answer: ADC can't be 25KHz. ADC minimum possible value is MCK/255 and the maximum is MCK/2. For 25000, your Master Clock Frequency should be 6375000. The function sysclk_get_main_hz() gives you the MCK for the SAM3X8E which is 84000000 (12nS). Thus, your desire ADC clock can be reached. May be we could help you a bit more if you tell us why you need 25KHz for your ADC clock? Regards!
