Topic: change ADC clock (Read 5032 times) previous topic - next topic
for reading analog voltage signal and I need to take 500 sample signals for the voltage sine wave.
frequency voltage signal = 50hz
sample rate = 25 khz
25000/50=500 samples for a period.
In a dedicated logic, given your current ADC clock (291666Hz), you should read the analog input 500 times per cycle using delayMicroseconds(11) between readings.
