Topic: how to measure the number of clock cycles from execution time of a code (Read 963 times) previous topic - next topic
sohini25
I am using micros() function to get the execution time of my code on Mega 2560. But can anyone tell me how to get the number of clock cycles required for executing it.
Riva
You have maybe posted this question in the wrong forum section?
What if you setup several global unsigned longs (maybe t0 to t9) and then call tx = micros() function tens times in a row (not using loop) and then compare the average difference between each call. This will give you something like the execution time though interrupts will effect the results. Run it enough times and you should get an idea of the time it will take.
The long winded way would be to disassemble the code and work out how many machine code instructions are needed but you will still have interrupt overheads to take into account.
Don't PM me for help as I will ignore it.
robtillaart
Arduino.h has these 3 macro's to help you
Code: [Select]
#define clockCyclesPerMicrosecond() ( F_CPU / 1000000L )
#define clockCyclesToMicroseconds(a) ( (a) / clockCyclesPerMicrosecond() )
#define microsecondsToClockCycles(a) ( (a) * clockCyclesPerMicrosecond() )
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
