This is the integer math version:
#define nelems(x) sizeof(x)/sizeof(*x)
const int Fs = 5000; // Sample Rate
const int D = 5; // Down sampling factor
float T = 1.0; // Acquisition Time sec
double meanValue = 0.0;
double stdValue = 0.0;
int volatile sampleInd = 0; // Global Buffer Location
int * volatile rawSignal; // Acquisition RAM Buffer
int * polySignal[D]; // PolySignal branches
int * polyIQ[2]; // Quadrature filtered, downsampled, demodulated signals
unsigned int * polyResult; // Reconstructed, LP filtered signal
// I-Q quadrature oscillations
const float I[D] = {2.0, 0.61803398,-1.61803398,-1.61803398, 0.61803398};// Cosine
const float Q[D] = {0.0, 1.90211303, 1.17557050,-1.17557050,-1.90211303};// Sine
// AntiAliasing filter coefficients :: FIR window Kaiser, Fs=5000, Fc=300
const float AAF[15] = {0.01786240,0.03388546,0.05089129,0.06751284,0.08232631,0.09400803,0.10148476,0.10405780,0.10148476,0.09400803,0.08232631,0.06751284,0.05089129,0.03388546,0.01786240};
float * polyAAF[D]; // Polyphase downsampled impulse responses
// LP filter coefficients :: FIR window Kaiser, Fs=1000, Fc=15
const float LP[21] = {0.04144742,0.04320807,0.04483017,0.04629891,0.04760078,0.04872372,0.04965724,0.05039261,0.05092289,0.05124307,0.05135014,0.05124307,0.05092289,0.05039261,0.04965724,0.04872372,0.04760078,0.04629891,0.04483017,0.04320807,0.04144742};
void computeOutput(){
timemicros = micros();
rawSignal[0] = rawSignal[5]; // First value adjust
int offset = 0; // Offset
for(int h=0;h<Fs*T;h++)
offset+=rawSignal[h];
offset/=Fs*T;
for (int i=0;i<Fs*T/D;i++) // Initialize arrays
polyIQ[0][i] = 0;
polyIQ[1][i] = 0;
for (int j=0;j<D;j++)
// DownSampling
for (int i=j;i<Fs*T;i+=5)
polySignal[j][i/5] = rawSignal[i]-offset; // Downsampling and offset removal
for (int i=j;i<nelems(AAF);i+=5)
polyAAF[j][i/5] = AAF[i];
// AntiAlias Filtering
filter(polyAAF[j],nelems(AAF)/D,polySignal[j],(int) Fs*T/D);
// Quadrature Demodulation
polyIQ[0][i] += I[j]*(polySignal[j][i]);
polyIQ[1][i] += Q[j]*(polySignal[j][i]);
// Norm calculation :: sqrt(I^2+Q^2)
polyResult[i] = (unsigned int) sqrt(polyIQ[0][i]*polyIQ[0][i] + polyIQ[1][i]*polyIQ[1][i]);
// LP filtering
filter((float *) LP,nelems(LP),(int*) polyResult,(int) Fs*T/D);
// Elaborate stats
statistics();
double convFactor = 2.0*4.0/65535.0; // 2 * FullScale / (2^16-1)
meanValue *= convFactor;
stdValue *= convFactor;
printResults();
polyFreeAlloc();
timemicros=micros()-timemicros;
Serial.println(timemicros);
bool polyAlloc()
if(NULL != rawSignal)
free(rawSignal); // Deallocate buffer memory
free(polyResult);
rawSignal = NULL;
polyResult= NULL;
rawSignal = (int *)malloc(Fs*T*sizeof(int)); // Dynamic Memory Allocation
polyResult = (unsigned int *)malloc(Fs*T/D*sizeof(int));
polyIQ[0] = (int *)malloc(Fs*T/D*sizeof(int));
polyIQ[1] = (int *)malloc(Fs*T/D*sizeof(int));
bool polys = true;
polySignal[j]= (int *)malloc(Fs*T/D*sizeof(int));
polyAAF[j] = (float *)malloc(nelems(AAF)/D*sizeof(float));
polys &= polySignal[j] != NULL && polyAAF[j] != NULL;
return (rawSignal[0] != NULL && polyIQ[0] != NULL && polyIQ[1] != NULL && polyResult != NULL && polys);
void filter(float *Num, int n, int *vect, int vLen)
int average = 0; // Initial conditions calculation
for(int h=0;h<vLen;h++)
average+=vect[h];
average/=vLen;
int numbuf[n]; // Initialize FIFO FIR buffer
for(int h=0;h<n;h++)
numbuf[h]=average;
for (int h=0;h<vLen;h++){ // Filtering cycle
int FIR = 0;
for (int k=n-1;k>0;k--) // Cycle FIR buffer elements
numbuf[k]=numbuf[k-1];
numbuf[0] = vect[h]; // Push new element inside FIR buffer
for (int j=0;j<n;j++) // FIR convolution
FIR += (int) numbuf[j]*Num[j];
vect[h] = FIR; // Output calculation
